Home > Tdi > Fuel: white smoke
Kit
United Kingdom 1993 Defender 90 200 Tdi SW Scotia Grey
Fuel: white smoke
My defender is over fueling (not using any water/oil), it's done 170K miles so it's probably due a new fuel pump but is there anything else it could be like worn injectors?
Also any recommendations on which fuel pump to buy? 1993 200 Tdi 90 CSW
1956 Series 1 Hard-top
1958 Series 1 Soft-top
Post #673019 24th Dec 2017 11:29am
trickster5000
United Kingdom 1989 Defender 90 300 Tdi CSW Arles Blue
Have you tried isolating each injector to see if it's a particular injector causing the problem? Or possibly water in your diesel? Matt.
'89 90 CSW with a 3.5 V8 conversion (WIP) - http://www.defender2.net/forum/topic46809.html
Post #673024 24th Dec 2017 11:40am
Kit
I recently put a new fuel tank in and I've put a couple of tanks of fuel through it so im pretty sure it's not water in the fuel.
How would I isolate which injector is causing issues if it is them? 1993 200 Tdi 90 CSW
Post #673026 24th Dec 2017 11:43am
trickster5000
With the engine running, loosen the union on each injector, one-by-one and see if the smoke stops Matt.
Post #673028 24th Dec 2017 11:45am
Kit
It's worth a shot, will a knackered injector cause mpg to drop? 1993 200 Tdi 90 CSW
Post #673036 24th Dec 2017 12:09pm
trickster5000
Well white smoke, if it's not water in the system, is usually very excessive overfuelling. Black smoke is overfuelling but the fuel still partially ignites whereas white usually indicated a significant excess. So yes, I would guess that if the white smoke is unburnt fuel from a faulty injector you would have a lot lower mpg?
All kind of guesswork but it makes sense in my mind Confused Hope this helps! Thumbs Up Matt.
Post #673038 24th Dec 2017 12:13pm
Kit
Yeah I agree, so theoretically when the union is loosened it should be obvious I hope!
Will let you know how I get on, thanks for the advice 1993 200 Tdi 90 CSW
Post #673048 24th Dec 2017 12:55pm
geobloke
Hi Kit. White smoke can also be oil bypassing the bearing seal on the exhaust side of the turbo. Can cause quite the amount of white smoke with not a great drop in oil level. Would be worth checking the play in your turbos impeller, especially axial in/out play. Should be negligible.
Post #673069 24th Dec 2017 2:53pm
jst
when is it worse? startup/underload/over run?
when was timing belt last done Cheers
James
110 XS Utility
130 Puma Station wagon/camper (in the making)
90 Puma Hardtop
Post #673117 24th Dec 2017 6:41pm
Kit
Timing belt was done recently (2 months ago) do you think it was setup wrong?
It's at worst on start up and incrementally gets better until the engine has fully warmed up
I'll check the turbo too Thumbs Up 1993 200 Tdi 90 CSW
Post #673171 24th Dec 2017 9:28pm
Blackhat90
Scotland 1995 Defender 90 300 Tdi HT Epsom Green
Yeh it will be one injector, do the slacken illiminator test, to find it, , i"v had this , lots of white smoke on start up. clears when engine is hot,, usually the idle is erratic when cold,, theres full sets of recon injectors on ebay, £190,
Post #673220 24th Dec 2017 11:51pm
geobloke
Sure check it, but it now sounds like this is not the cause. Sounds like a timing or fuel pump issue.
Post #673223 25th Dec 2017 12:05am
Kit
Any recommended sellers? 1993 200 Tdi 90 CSW
Post #673232 25th Dec 2017 1:25am
Procta
kit, id change the glow plugs in case that's causing problems, sometimes one can go down causing some white smoke at start up. My Dturbo had this problem. before you go about injectors as mentioned, and also change where you fill up in case its a bad batch of diesel Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #673238 25th Dec 2017 3:01am
jst
I would check timing belt first for piece of mind Cheers
James
110 XS Utility
90 Puma Hardtop
Post #673252 25th Dec 2017 8:59am
