Home > Maintenance & Modifications > Fitting IFW canopy to 110 DC |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16884 |
Drill out the rivets, remove the drip rail, and seal the holes.
(Been there, done that!) |
24th Dec 2017 1:21pm |
miket Member Since: 05 Oct 2012 Location: Peak District Posts: 143 |
Thanks Blackwolf. I was a bit reluctant to make more holes in the cab having had to work hard to get it (mostly) dry, but drilling the rivers seems like the best way.
What’s best to seal the holes up with? |
24th Dec 2017 4:02pm |
geobloke Member Since: 06 Nov 2012 Location: Nottinghamshire Posts: 4406 |
Best way is to use another blind rivet to seal the hole, but make sure you use the sealed versions LR use not the cheap ones that will let water through.
24th Dec 2017 5:22pm |
24th Dec 2017 5:25pm |
Depends if you think you'll ever want to refit the tilt frame. If definitely never, sealed breakstem fasteners (rivets), if you think you might, then an M5 machine screw with a nyloc and a dab of sealant. Alternatively I whacked a small square of Gorilla tape over each hole as a temporary measure, and 7 years later they're still doing a great job.
24th Dec 2017 7:06pm |
Ta! Drilling out the rivets it is then and then screw and nylon bolt.
Thanks for the feedback! Mike |
24th Dec 2017 10:26pm |
