Home > Technical > Brake Disc shields |
DieselBeast Member Since: 27 Sep 2017 Location: UK Posts: 33 |
Are they easy enough to remove?
I had a feeling the front shields were bolted through the kingpin bolts... Or is that just a bracket |
13th Dec 2017 9:12pm |
Yeah pretty easy. 1x small 10 or 13mm bolt/nut and then the nut of the steering lock.
13th Dec 2017 9:46pm |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4784 |
Yeah as geobloke says one 10mm bolt and the steering lock stop nut. Then slides off forwards 2002 90 Td5 Station Wagon
13th Dec 2017 10:46pm |
Also road wheel off 2002 90 Td5 Station Wagon
13th Dec 2017 10:47pm |
Just had a look. Easy peasy... Well as easy as those rusty bolts are to get out!
16th Dec 2017 12:13am |
NMBRPL8 Member Since: 07 Jul 2015 Location: Australia Posts: 144 |
Its the only bit Ive had trouble with on my 2015MY..
Came loose a couple of times and rattled. Lost a fastening bolt and rattled. Currently broken and requiring replacement. Steel should have been half a millimetre thicker. |
16th Dec 2017 12:18am |
