Home > In Car Electronics > Anyone fitted a pumpkin double din Android unit to a Puma |
alastaid Member Since: 03 Dec 2013 Location: York Posts: 78 |
Hi,
I have bought one of these: https://www.amazon.co.uk/Pumpkin-Bluetooth...double+din To replace my Parrot Asteroid, but it turns out Double Din isn't "standard". The pumpkin unit is approx 10mm wider and 5-6mm taller. Hence I either: a) send it back and look for another unit that fits - any ideas, but I like this is as it is good spec, and pretty much native Android b) take a hacksaw to my double din fascia which doesn't appeal. Anyone been down this route and got any wisdom? Thanks Alastair |
10th Dec 2017 4:33pm |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2077 |
I'd cut and make it fit. Soon as the trim surround is on you'll never notice.
10th Dec 2017 5:55pm |
okami Member Since: 06 Apr 2017 Location: Hertfordshire Posts: 90 |
I have the same clone receiver though not a pumpkin in my TD5 dash with the Raptor fascia. I had the same issue with the unit being a bit larger than double DIN.
My solution was to mount the radio from the inside of the fascia as the bezel is DDIN. The trim ring was installed afterwards. It makes pulling the stereo a bit more difficult as it requires pulling the center dash, but would confuse any thief looking for a quick score. I can't comment if the same would work with a Puma. -j |
10th Dec 2017 6:37pm |
Thanks for all the replies, so after much searching and measuring, it looks like Pumpkin has two versions of Double Din (maybe other manufacturers do to):
There is this "universal Double Din" which doesn't fit a Puma: https://www.amazon.co.uk/Pumpkin-Bluetooth...double+din and there is this "standard Double Din" which I have now ordered and hope does fit: https://www.amazon.co.uk/Pumpkin-Android-B...double+din Perhaps I was naive to think "universal double din" was different from "standard double din", anyway, they will both be from Amazon, the first is going back tomorrow, and if the next one doesn't fit that will be going back as well, just wanted to make sure if other go down this route not all double dins are equal, I will report back if the "standard Double Din" fits when it arrives. Cheers Alastair |
10th Dec 2017 11:17pm |
nicks Member Since: 21 Aug 2008 Location: south coast Posts: 469 |
there are 2 sizes of double din 6 or 7.1"
the defender DD kit is for 6" head units. |
11th Dec 2017 6:22pm |
