Home > Tdi > oilpressure warning light |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3615 |
change the oil pressure switch first, if you can find an oil pressure gauge fit this and see what pressure you have, after that its the pump or engine wear, but a gauge will tell you what is happening and when. DEFENDER 90 TDCI XS,
27th Nov 2017 7:21pm |
Devon-Rover Member Since: 22 Jan 2015 Location: South Devon Posts: 907 |
Rear camshaft bearing can shuffle out of position, you usually get this as a first sign before the light being on all the time at idle before it stays on all the time. After checking the sensor is fine I would pull off the side plate to have a looksee.
27th Nov 2017 8:13pm |
juko Member Since: 02 Dec 2016 Location: Leeuwarden Posts: 19 |
i am going to the garage tomorrow. Hope it will be an easy sensor replacement.
27th Nov 2017 10:16pm |
Hazza Member Since: 10 Jan 2011 Location: North Yorkshire / Leeds Posts: 208 |
I had a very similar issue, solved by a replacement oil pressure switch 1990 Defender 110 200TDI Camper - now converted to Td5 power
27th Nov 2017 11:17pm |
thank you all for your input.
28th Nov 2017 8:10am |
