Home > Wheels & Tyres > Bfg mud terrains... |
Arierep Member Since: 13 Apr 2013 Location: Portugal Posts: 258 |
JOW240725,
Yes, I used to run Wolfs with hubcentric spacers. Quite a nice setup. Ended up swapping the Wolfs and spacers for 16x8j -25mm offset rims. Wanted a wider rim and a wider track. Spacers never gave me problems, but definitely feel better without them. Regarding suspension lift and tyre clearances, don't forget that unless you change the bumpstops your actual clearance stays the same. You just need a bigger bump or a heavier load to run the tyre |
21st Nov 2017 11:55am |
Timcat Member Since: 20 Jul 2016 Location: Tanzania at the moment Posts: 1014 |
Blackwolf that’s exactly the same place as mine but on the near side.what 2” lift are you thinking of?
21st Nov 2017 4:23pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16902 |
I am thinking of an upgrade to OME springs, since most of the time my Defender is quite well-laden. I am also thinking of fitting a full external SD cage will will increase the weight still further.
I plan to run it onto a weightbridge when I get the chance to establish its typical in service weight, after which I can make some more informed choices about springs etc. |
21st Nov 2017 4:38pm |
Think we are on the same wave length, after seeing a 110 roll on the dunes in Morocco I’m also thinking roll cage...
21st Nov 2017 4:52pm |
