Home > Wheels & Tyres > BFG Mud no m&s?!
churchy
2007 Defender 110 Puma 2.4 XS CSW Java Black
BFG Mud no m&s?!
Hi all,
KM2s just noticed that the new ones I have had fitted are not marked with m&s as my old ones were?!
Not overly fussed but I know the local gendarm likes to inspect tyres if they have a check point where we go at Christmas.
Any clues......?
Post #663142 10th Nov 2017 4:37pm
JOW240725
I looked at the BFG website to see if I could answer your question, but with no joy.
However, I looked at the label for BFG KM2 255x85R16 and they seem to carry an A rating for both fuel efficiency and wet handling and quiet Dba.... that can't be right, can it??
 James
Instagram @suffolk_rovers
Post #663148 10th Nov 2017 5:03pm
jst
i dont recall the MTs ever having the snowflake symbol. off to check now though, memory not like it was! Cheers
James
110 XS Utility
130 Puma Station wagon/camper (in the making)
90 Puma Hardtop
Post #663150 10th Nov 2017 5:12pm
camelman
It's only the KO2s that are winter rated.
Post #663152 10th Nov 2017 5:16pm
churchy
Ko2 is the all terrain right?
Maybe I am wrong but I am convinced my old tyres had m&s marked on them.........
Post #663157 10th Nov 2017 5:36pm
churchy
Took some late night googling but here is the proof - found quite a few photos where they are clearly marked however agreed not with snowflake. Might have to zoom a little. There are better pictures agreed but it's just above the a of terrain.
Post #663345 11th Nov 2017 8:53am
Having the letters M&S is not the same as having the Mountain/Snowflake symbols. Only the latter means winter rated. Darren
Post #663346 11th Nov 2017 9:03am
churchy
Fully appreciate that but then what's the point of having it marked or not marked as the case may be!? At least I've proved my memory is not quite gone!
Post #663349 11th Nov 2017 9:09am
dorsetsmith
The severe service winter tire designation looks like a peaked mountain with a snowflake in the middle. When you see a tire with the mountain snowflake pictograph on the sidewall, you know it meets specific snow traction performance requirements set by the Rubber Association of Canada.
A sidewall mark of M+S (or M/S, M&S, MS) means that you have an all-season tire that has been approved for use in mud and snow by the Rubber Manufacturer's Association (RMA). These tires will provide traction in light snow, but we wouldn't want to be caught in a blizzard with a set of M+S tires.
Post #663355 11th Nov 2017 9:30am
They just mean different things. M&S stands for Mud and Snow and indicates an open tread that will work well with those sorts of loose surface. The Mountain/Snowflake symbol indicates that the tyre is good for much lower temperatures, typically below 6C, where the M&S tyre becomes less effective.
There's more detail here: https://info.kaltire.com/what-is-the-winter-tire-symbol/
Edit:
Sorry, I've just re-read your original post and realised what you mean. I don't know why the the KM2's aren't marked 'M&S'. Perhaps they consider it unnecessary given the obvious tread pattern. Darren
Post #663358 11th Nov 2017 9:41am
churchy
Great thanks all - only really asked because the gendarme passed me clear due to the m&s rating last year on a road to a ski station where you are required to have either chains or snow tyres. My 2p worth is that the mud terrains performed superbly in varied snow conditions last year from foot deep to compacted - maybe because I stayed with the thinner profile?
I guess BFG have removed the lettering to encourage folk down the more specific winter tyre route.
Post #663360 11th Nov 2017 9:47am
dorsetsmith
also EU give BFG 235 85 16 AT 2 KO and older AT KO tyre with snow flack (summer rating ) Whistle Whistle run with tyres all year and in deep snow and ice Thumbs Up
Post #663371 11th Nov 2017 10:28am
JWL
When you look at the eBay shop adverts 9/10 say Summer Tyre in their descriptions of the KM2
Post #663600 11th Nov 2017 11:37pm
camelman
After running both ko2 and km2 thru the last few winters, I can confirm the ko2 are way better in snow and ice.
Post #663652 12th Nov 2017 10:42am
I guess you could say the key is in the tyre name and type.
Snow or not I'd not swap my KM2's, they are far more use to me than an ATR in general conditions.
I not longer drive in snow and ice anyway, as it's so much of a risk it's just not worth it.
It doesn't matter what you are running it's a high risk especially of damage. Diesel$ Live$ Matter. ⛽️🛢️👨‍🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
Post #663658 12th Nov 2017 11:09am
