Home > Maintenance & Modifications > Panhard Tdci vs 300tdi |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2201 |
In 02' the panhard rod went from an M14 to an M16 bolt fixing at either end. I assume this remained the same throughout TDCI.
To fit the later axles you will need the panhard rod which matches the axles and the arm which connects to the other end of the panhard rod from a post 02' vehicle. If calipers and discs are serviceable then stick with solid for now. If replacements are needed then go to vented. Unless you are towing a lot vented will make no noticeable difference. Steve 02' 110 TD5 Double Cab Rebuild Thread 84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale |
12th Oct 2017 2:12pm |
benspray Member Since: 31 Jul 2014 Location: Norfolk Posts: 159 |
Thanks Steve,
Do you know, is the only difference in the bracket at the chassis end in the hole size? ie can I just drill mine out to 16mm or are there other differences to the location/bend/offset etc? And yes the discs pads and calipers are all brand new so will leave them as is for now (my only concern was being on the brakes more than usual with it being an auto) Cheers Ben |
12th Oct 2017 2:40pm |
shropshiredefender Member Since: 05 Jun 2017 Location: Shropshire Posts: 832 |
Had an '02 (straight) Panhard rod fitted to my '96 300tdi, rather than drilling the chassis fixing out simply replaced the bracket with a Disco 2 item.
Oh and thinking about it the front axle case was Disco 2 as well! Good luck with your project. Just because you're offended doesn't mean you're right. Last edited by shropshiredefender on 14th Oct 2017 11:11am. Edited 1 time in total |
12th Oct 2017 2:56pm |
The bush is physically bigger so I believe you need to change the bracket.
12th Oct 2017 3:37pm |
Will be a galvanised bracket, adjustable panhard, and super pro bushes all new for sale shortly then Thanks Ben |
12th Oct 2017 4:53pm |
