Home > Technical > Braided Brake Lines - TD5 and Puma Differences |
Harry.O Member Since: 25 Jul 2014 Location: Warwickshire Posts: 708 |
I'm due to change the brake fluid soon and whilst I have to bleed them, thinking of changing the flexible brake lines for stainless braided versions.
Whilst looking around at different brands, I noticed that Extreme 4x4 list 2 different versions dependent on whether it's a Puma or pre-puma version. Did LR change the union sizes or is there another difference? Thanks, Harry http://www.extreme4x4.co.uk/Store/Extreme-...s-defender 2005 Td5 110 Hardtop 1989 300Tdi 90 Soft top 1992 200Tdi 90 Truck cab with Land Cruiser axles |
6th Oct 2017 3:51pm |
Thanks for the quick response Dorsetsmith. I don't have ABS or the dual circuit front calipers so looking at the 3-hose kit. Is it safe to assume that Td5 and Puma hoses are not interchangeable? 2005 Td5 110 Hardtop
6th Oct 2017 7:00pm |
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 |
Give llama 4x4 a call, he knows his stuff and good prices too
6th Oct 2017 7:47pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7750 |
As above speak to David at llama, he's head done all my brake pipes for my own vehicles and rebuilds for last 12 years. Consider banjo fittings straight to caliper Cheers
James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
6th Oct 2017 8:50pm |
Thank you guys, I'll give Dave a call. Banjo fittings direct to the calipers is a good suggestion, much easier to take the calipers off for maintenance later on. Thanks, Harry 2005 Td5 110 Hardtop
9th Oct 2017 9:38am |
