Home > Td5 > Instrument panel bulbs ( FIXED)
Djcla
Hi
I've noticed I have no hand brake light on my dash and I suspect others might be out too. Is there any tests you can do to get them all to light up? What bulbs are they so I can get led replacements and how do you access them?
Post #654707 3rd Oct 2017 9:57pm
SteveK
United Kingdom 2002 Defender 110 Td5 HT Rimini Red
Before you start going too far down the dismantling route, have you checked that all of the connectors including the one to the dash panel are full pushed home?
Post #654718 3rd Oct 2017 11:56pm
Djcla
Nope I'll double check as that's a fair point, but just figured bulbs are out because I've had a few not working when I bought it
Post #654733 4th Oct 2017 7:21am
rallysteve
The TD5 warning lights are LED and not removable. I doubt that they have actually stopped functioning however, the issue is likely to be the wiring or switch/sensor on the end.
If it is the handbrake light then it is probably the wire detached or damaged as it is quite exposed to damage under the seatbox. Failing that it will be the switch on the level. A quick test is to remove the rubber gator from the handbrake lever, remove the spade terminal from the switch and touch it/ use a length of wire to connect it onto one of the mounting bolts to connect directly to earth. With the ignition on this should illuminate the light.
Which other lights are not working?
84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale
Post #654736 4th Oct 2017 7:38am
dorsetsmith
1.If you lift the centrer seat front and remover the metal plate handbrake light cable can be fond with small black
inline connector you can test wiring and Instrument panel LED by earthing none handbrake switch end cable to the transfer box with key switched in position two handbrake Instrument panel LED shod light if not check fuse 15, 5 amp passenger compartment and also earthing cable on driver side transfer box
2. Also test low Fluid level brake switch on top of brake master cylinder with key switched in position two handbrake Instrument panel LED shod light
3. if test all ok next check handbrake switched one end earth to side of the handbrake on the seat box, handbrake switched also has short length cable with inline connector
Post #654743 4th Oct 2017 8:37am
Djcla
Steve
not 100% sure will need to try and test them all one by one , perhaps its just the handbrake
Post #654764 4th Oct 2017 9:45am
Djcla
At the risk of sounding thick where would i find the master cylinder ?
Post #654766 4th Oct 2017 9:46am
dorsetsmith
Post #654808 4th Oct 2017 11:32am
Djcla
So looks like I found the issue, where is it supposed to be connected?
I've also got another slight problem In that I can't get my air flow adjusters to light up either side of instrument panel. I've changed the bulbs to led and they still don't work, wiring looks ok too. What is the best way to test?
Post #655359 6th Oct 2017 2:21pm
dorsetsmith
make shore led are fitted or wired right way a round
Post #655362 6th Oct 2017 2:30pm
Djcla
lol taht was simple totally didn't realize it mattered what way around the bulb went feel silly now Smile
Any ideas where the hand brake connector connects too?
Post #655370 6th Oct 2017 2:47pm
dorsetsmith
http://www.allbrit.de/UNI.cfm?PAGE=756390&SPRACHE=EN
switch is fitted to head brake ( item 2 )
Post #655372 6th Oct 2017 2:52pm
Djcla
yes i found a bit with a click button on it under the gator , so looks like it needs connecting some how . Ill take another look more photos incoming i feel. Thanks for the help.
Post #655374 6th Oct 2017 2:57pm
dorsetsmith
Post #655385 6th Oct 2017 3:32pm
Djcla
i have a feeling mine has snapped off , ill investigate further tomorrow
Post #655440 6th Oct 2017 6:31pm
