Home > In Car Electronics > CB radio recommendation
MC84
United Kingdom 2001 Defender 90 Td5 HT Chawton White
Can anyone suggest a good, small CB radio for my truck please? I'm looking for a physically small footprint ideally. Thumbs Up Thumbs Up Mike
Hard Top 90 TD5 2001
Ford 100e 1959
www.youtube.com/mikemakesit
Post #653899 30th Sep 2017 7:07pm
300TDi CSW Phil
United Kingdom 1995 Defender 110 300 Tdi CSW Epsom Green
This one is really small
Albrecht AE6110- reportedly a good radio
or this one which looks identical
CRT One- allegedly a copy/rebranding of the above
Lafeyette do one called the Venus where the screen, microphone and speaker were all in the fist mic and then a small box could be hidden away but it is more than twice the price of the first two.
The 1st two are available fro 4x4cb.com who I have dealt with and are superb.
The Lafeyette is listed on the thunderpole website.
Personally I have a TTi TCB 900 with the front facing speaker but it does take up a single din slot with the DIN mounting kit and is not a great deal smaller without it (but it is short front to back). 1995 300 Tdi Epsom Green - It's a keeper.
Wide Track Sankey- In bits- Gone to a new home
M0XQS
Post #653902 30th Sep 2017 7:36pm
L110CDL
I use this one, it's a Thunderpole T800 nice and small, the only problem with it was the speaker was underneath, so i put a better speaker just above the CB so i can hear much better now Very Happy......................
Thumbs Up 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton.
Post #653984 30th Sep 2017 10:03pm
MC84
I'm liking the look of the Albrecht AE6110. Certainly as a starter. Any advice on the aerial Guys? I have been looking of the 4x4cb site, quite a lot to look at! Mike
Ford 100e 1959
Post #654010 1st Oct 2017 4:46am
300TDi CSW Phil
I have one of the Sirio HiPower antenna's mounted through the front wing which gives pretty good results but is slightly directional.
I used to have a long springer which wasn't bad and was a lot bendier whenever it hit anything (that said I haven't managed to break the Sirio either).
One issue with the Sirio antenna's is that they use a special SO239 base (much like amateur radio antenna's) rather than the 3/8 stud that most CB antenna's use so if you wanted to be able to change from one to the other you need an adaptor which is available but not cheap (for what it is). It is only possible to convert the SO239 to a stud and not round the other way.
A lot of Defender owners mount their CB antennas on the rear vertical section above the gutter line (normally on the offside) on a PSM-1 mount. This puts your antenna nice and high but will limit you to a springer type antenna as they have a 3/8 stud mount and you will hit trees (I have my amateur radio antenna's on the roof rack and they shake trees all the time, hence I have to get versions with springs or very bendy whips depending on type).
You will also need an SWR meter so you can correctly tune in the antenna. 1995 300 Tdi Epsom Green - It's a keeper.
M0XQS
Post #654038 1st Oct 2017 9:34am
VeeTee
Netherlands
I have an Alan Midlan 42 Multi, it is a handheld (porto), but you can exchange the batterypack for a connection to an external 12V supply and external (fixed) antenna. So then it is really small and added bonus you can take it with you outside of the vehicle. I also have a fixed setup (also Alan Midland), so this is a handy way of communicating while the co-driver/navigator is outside giving instructions negotiating difficult tracks.
 Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #654041 1st Oct 2017 9:51am
Scott_Landy
United Kingdom 1993 Defender 110 200 Tdi CSW Firenze Red
I've got a T1000 which is good.
Interesting one in LRO this month that has a twelve volt socket so no need wire in as such. For Seventy quid.
Post #654052 1st Oct 2017 10:16am
MC84
Thanks everyone for their input. I'll probably go for the cheaper end of the market for a starter unit, fixed in the truck and see how it develops from there.
I was thinking of fitting the aerial at the back near the gutter, fixing to the vertical side above the small rear window (next to the door) as there is already a hole but the truck usually lives under a carport so I'm restricted on height so may have to go for a wing fitment. Mike
Ford 100e 1959
Post #654114 1st Oct 2017 4:04pm
VeeTee
Netherlands
I have my antenna at the back as you plan to do - I used a hinged coupler for that purpose between (springer)antenna and mounting base.
 Cheers, Vincent
MySite
Post #654128 1st Oct 2017 4:42pm
MC84
Hi VeeTee, I just need to remember to drop it before I reverse the truck under the carport!!! Mike
Ford 100e 1959
Post #654130 1st Oct 2017 4:47pm
L110CDL
As i dont use my CB to much, i got one off these .....................
When the aerial is on.........
Very Happy Thumbs Up 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton.
Post #654254 1st Oct 2017 10:29pm
CarMan
I will probably only use it twice a year so think I might push the button on the Midland 42 Multi handheld at £110, unless anyone has any better ideas? Rob
1993 200tdi 90 hard-top
1998 300tdi 90 soft-top
2016 2.2 XS 90 hard-top
Post #659605 25th Oct 2017 4:59pm
VeeTee
Netherlands
^ good choice. Thumbs Up Cheers, Vincent
MySite
Post #659607 25th Oct 2017 5:01pm
Devon-Rover
I run the Polmar Venus or as it is known now the Lafayette Venus. It is a lovely if not a little full on CB that runs all the different settings for lots of countries. you can fiddle with all the settings to you hearts content.
It hides under the cubby box and the mic hangs from the rear view mirror. there is a speaker in the base as well as the mic head. All the buttons is on the head so it is a compact and convenient unit, not to mention the speaker is clear and easy to understand.
The antenna is on the front A bar and running a 4 foot firestik or a Thuderpole red devil gives good range when in use.
Post #659644 25th Oct 2017 8:12pm
Scoobeenut
United Kingdom 2010 Defender 90 Puma 2.4 SW Santorini Black
Devon-Rover any pics of your setup? Sounds interesting, I was contemplating fitted an aerial to my front A-Bar, do you find it distracting fitted on the front?
Post #659714 26th Oct 2017 8:07am
