Home > Tdi > 300tdi gearbox installation |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1758 |
I would be double checking if the clutch is centred properly.
I managed to get mine on with a bit of jiggling and fiddling with the engine crane! |
18th May 2017 5:41pm |
Outlaw1 Member Since: 11 Aug 2016 Location: east sussex Posts: 266 |
Hi Ollie130 Had a gearbox fitted in mine recently and the mechanic disconnected the rad hoses . Then iacked the front of the engine so to give more room at the rear . Worked a treat and went straight in . Hope this helps
18th May 2017 5:53pm |
DieselBeast Member Since: 27 Sep 2017 Location: UK Posts: 33 |
I usually take the engine out for a clutch change. It sounds more long winded but potentially quicker in the long run, and less time on your back. You can get a good angle with the gearbox jacked up and it slots right in (With a bit of wiggle)
I think the first thing is making sure the friction plate is lined up, A light dab of that red grease on the splines. Then getting the right angle. If it won't go i turn the crank a little then try again. I also put the gearbox in neutral, i'm not sure if this helps or it's my superstition. Don't be afraid to take it off and start again. Sometimes it just goes. All else fails, a plank of wood and a hammer always helps. |
27th Sep 2017 10:46pm |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2079 |
^^^^^ what dieselbeast said.
Mo The Land Rover 90 - Many are called, few are chosen. |
28th Sep 2017 7:40am |
