Home > Td5 > Changing wiper park position?
BCdefender
Canada 1999 Defender 110 Td5 CSW Orkney Grey
Hi there,
Has anyone had experience with changing the park position of the passenger side wiper's? When the wipers are running the passenger side wiper falls below the seal and makes a loud noise.
Here's a photo of where the wipers park.
 1999 Defender 110
2003 P38
2007 RR SC
"And that's why it needs to be celebrated, because when the Defender goes we'll have lost this pointer to where we came from, and we're really going to miss it."
My build thread: http://www.defender2.net/forum/topic47750.html
Post #651325 19th Sep 2017 5:07pm
mk1collector
Pop the cap at the bottom of the wiper arm, undo the nut, take the arm off and reposition where you want it then put the nut back on Thumbs Up Ray
My build thread
Post #651330 19th Sep 2017 5:25pm
Balvaig
It may be that the wiper mechanism is worn out, but if there is no free play in the passenger side wiper arm then I would remove the arm and re position it on the splines.
Post #651331 19th Sep 2017 5:26pm
BCdefender
Thanks guys.
I will give it a try! Thumbs Up
There is a bit of play but the whole mechanism was completely replaced about a year ago Big Cry 1999 Defender 110
2003 P38
2007 RR SC
Post #651337 19th Sep 2017 5:33pm
agentmulder
Kuwait
I did this all a few months back, cant remember the names of everything buuuuut:
If the nut on the stud is nice and snug and similarly the wiper is heard to remove then it's likely that the springy rack thingy and pinion/housing have worn. Reseating the wiper will just give the rack another opportunity to slip again (note how it currently stops once it has hit the lower window seal instead of putting further force on the rack)
Opening the dash then flipping the springy rack thingy over in the motor/arm/spinny thingy assembly and also checking the plates on the wiper/pinion assemblies haven't spaced out over time may give you a another winters worth. Thumbs Up Solved the bowel problem, working on the consonants...
Post #651402 19th Sep 2017 11:03pm
BCdefender
"springy rack thingy and pinion/housing have worn"
That's exactly what it was.
I still changed the park position so now it parks above the sill or in the middle of the window.
Will need to scour the parts book and figure out what I need!
Thumbs Up 1999 Defender 110
2003 P38
2007 RR SC
Post #651963 22nd Sep 2017 2:30am
agentmulder
Kuwait
If it parks in the middle too then I think the relayey-switchingy-mechanismy-abob is worn. Solved the bowel problem, working on the consonants...
Post #651968 22nd Sep 2017 3:00am
Coatesyyy
Thumbs Up
Post #652096 22nd Sep 2017 4:15pm
BCdefender
That's exactly what it is. Rolling with laughter
I will look through the parts book tonight for the real name and # 1999 Defender 110
2003 P38
2007 RR SC
Post #652100 22nd Sep 2017 4:22pm
