Home > Td5 > Faulty fuel gauge readings |
HansT Member Since: 25 Dec 2012 Location: Mariefred Posts: 173 |
After replacing the fuel pump, the fuel gauge readings are incorrect. When the gauge shows 1/2 tank, I can fill 55 litres. I take it that I managed to bend the rod to the float when fitting the pump.
Are there any measurements that I can check when I take out the pump again to fix the problem? Like distance between bottom of float to bottom of pump? |
14th Sep 2017 10:52pm |
JJ Member Since: 18 May 2009 Location: Winchester Posts: 932 |
Same thing happened to me . Fitted by a professional
I rarely run low on fuel so it was a long time after the pump replacement that I realised the problem. Quite common apparently to bend the rod. HR064 Hampshire and Berkshire 4x4 Response |
15th Sep 2017 4:27pm |
Yes gazman, I think you are right. I bought the pump long time ago and there was some confusion about the part No at that time and I also paid much less then what I expected.
Now when you mentioned it I also recall that the difference between the two is the complete fuel gauge sender unit on the pump. I saved the old pump so today I removed the sender unit from this and I will fit it to the new pump. Do you think this will work? |
15th Sep 2017 5:13pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6038 |
Yes it will.... disco and defender "pumps" themselves are identical.
Just the float arm needs swapping over. And strangely enough; if you buy one new the disco one seems to be a tad cheaper. |
15th Sep 2017 6:37pm |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4784 |
Yeah disco one is cheaper, I had the same when I helped our neighbour with his Td5 fuel pump. Disco one about £40 cheaper I seem to recall 2002 90 Td5 Station Wagon
15th Sep 2017 6:43pm |
