Home > Tdi > Considering taking 'Grover' to Germany to live .
shayes
United Kingdom 1998 Defender 90 300 Tdi HT Coniston Green
Morning all,
Need some help/advise please. Considering taking our 300TDI to live with us in Germany next summer. It's a 98 'R' reg 90 hard top. Apart from the headlights being swapped over, is there any other things we need to think about/resolve?. The chassis/ bulkhead are fine and it's being wax oiled next week locally. We are keen to take him with us next year and not sell/buy another one over there. We have just got him sorted to our tastes, and don't really want to start over again with a new one.
Someone mentioned it might need a Catalytic convertor fitting. Is there any other things that may crop up in registering him over there. I have identified a Independent Land Rover specialist close (3.5 hrs away) to the area we hope to settle in. Anyone have an idea about road tax over there.
Thoughts/ advise please.
Kind regards, S.
Post #650223 14th Sep 2017 8:29am
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
Hi,
are you going to permanently move to Germany (i.e. to register your home address over here?)
If not, it might be easier to retain your TDI's UK reg and just make sure you have MOT and insurance.
If you need to register Grover in Germany, the general concept is that it needs to comply with the technical state that was approved for the model at the time it was released in/for Germany (1998 probably). I'd indeed ask a specialist for the details. The keyword is "TÜV" - our short for MOT, although TÜV actually is the organisation doing the MOT inspection (so same confusion as with MOT when you first hear it as a foreigner Smile. You will need to visit them to get the papers needed for registration.
Road tax depends on emmission class ("Euro x") and cc
Here's a calculator: http://www.bundesfinanzministerium.de/Web/...chner.html
Highest tax for an "old" Diesel with 2495cc: 969€, lowest under 400€ p.a.
So depending on the "TÜV" regulations "to make Grover German" Wink you might be required to add a "Kat" (catalytic converter) or if it is not required but available, you might install it to reduce road tax.
Once you have the papers you can look for an insurance. They need some codes from those papers. They in turn give you an insurance number. Having both you can go to our equivalence of the DVLA (yes you actually have to GO there...) and get your reg.
Post #650236 14th Sep 2017 10:26am
NickEJ
Slovenia 2004 Defender 90 Td5 XS CSW Galway Green
Not only headlights but I had to also swap the rev and fog lights over. Simple job which only took about 30 minutes as you just need to swap the lampholders over and run wires from the original loom.
Good luck with the registration process. Took me about 8 weeks here as no-one seemed to know what to do!
Post #650238 14th Sep 2017 10:41am
shayes
Thanks for that, didn't even think about the rear lights. Is the road tax expensive?, cheers S.
Post #650240 14th Sep 2017 10:47am
NickEJ
I can't answer that as, for complex reasons that I won't go into on here, we are exempt from Road Tax.
Post #650241 14th Sep 2017 10:49am
shayes
Thanks guy's. Will digest your info and give it thought. Best regards, S.
Post #650251 14th Sep 2017 11:50am
