Home > In Car Electronics > Installing BBUS into TD5
Harry.O
United Kingdom 1989 Defender 90 300 Tdi ST Nato Green
I'm about to fit a BBUS and extension loom into my 2005 Td5 Defender. Does anyone know if there is a process to install it or do you simply bolt it in, connect the plug and enable it via Nanocom?
Thanks, Harry 2005 Td5 110 Hardtop
1989 300Tdi 90 Soft top
1992 200Tdi 90 Truck cab with Land Cruiser axles
Post #649612 11th Sep 2017 5:30pm
I don't think you even need to enable it, just bolt it in and plug it in. Td5 should have the correct harness for a standard installation unlike the Tdci which doesn't.
Post #649635 11th Sep 2017 7:39pm
Vogler
Belgium 2015 Defender 110 Td5 HT Chawton White
Sorry for asking, but what is a BBUS?
Greetings,
Joris
Post #649675 11th Sep 2017 9:17pm
Battery Back Up System for the alarm. Darren
Post #649681 11th Sep 2017 9:25pm
Vogler
I see, thank you!
Joris
Post #649690 11th Sep 2017 9:43pm
Harry.O
Thank you Blackwolf, I'll have a go later on. Once fitted is there a way to test that its working? Looking at the wiring it seems that unplugging it will cause it to sound? 2005 Td5 110 Hardtop
Post #649821 12th Sep 2017 12:57pm
Two tests are worthwhile:
1. Open the drivers window, then lock the car with the fob and wait for the alarm to arm. Then reach in and unlokc and open the door, the alarm shoudl sound and the BBUS should be heard.
2. Disconnect the battery (but allow several minutes after stopping the engine before you do so to make sure that the alarm is armed), the BBUS should sound.
Post #649823 12th Sep 2017 1:23pm
Harry.O
Fab, thank you for the quick response Thumbs Up 2005 Td5 110 Hardtop
Post #649824 12th Sep 2017 1:38pm
