Home > Td5 > Grinding TD5 starter motor
Justtellme
Canada 2003 Defender 110 Td5 SW Oslo Blue
So it seems my starting motor is getting worse.
Normally every tenth start, or so, my starter motor would fire, but not engage to the ring gear resulting in a horrible teeth shatterring noise....it has recently become worse with the starter doing it at 50% of the time now which can be quite embarassing, not to mention the concern with the potential damage it is doing to the teeth on the pinion and ring gear.
Does anyone know if this can be fixed with the starter rebuild kit with the plunger....or should i look at a new starter or a new dual mass fly wheel? The DMF has started the ocasional 1:1 vibration at idle suggesting lazy damper springs as per a previous thread...... anxiuosly awaiting some sage Defender2.net advice on where to focus my efforts next........
Patrick
Post #647687 1st Sep 2017 8:19pm
JWL
To be honest with how cheap the solonoid plunger kit is why not give it a try. It may just be that the contacts aren't good enough to throw the driver into the starter ring fully giving you those tooth crunching moments.
Post #647699 1st Sep 2017 10:16pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
^^^^agree with JWL^^^^ cheap easy and half hour of your life to change it up. If its no good get a new or rebuilt starter. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #647714 2nd Sep 2017 2:11am
Justtellme
Yes, that was my first thought and ordered up the plunger/ rebuild kit last night. Ill report back once i get it cleaned and reinstalled.
Thanks
Patrick
Post #647716 2nd Sep 2017 6:37am
rallysteve
Unfortunately the starter solenoid on the 205 is just a solenoid and does not move the pinion gear forwards.
Well worth removing the starter for a look though. Might just be able to clean it up. 02' 110 TD5 Double Cab Rebuild Thread
84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale
Post #647733 2nd Sep 2017 10:38am
Justtellme
What drives the pinion forward to engage then or is like the old helical engage drives?
Is there another solenoid?....can it be serviced?
Are you thinking only a new starter would fix things?
Patrick
Post #647751 2nd Sep 2017 1:43pm
