Home > For Sale & Wanted > [For Sale] Sankey Trailer for Sale |
tyrannosauROSS Member Since: 24 Jun 2016 Location: Kent Posts: 136 |
any more info? what model is it? does it have a chassis plate with info on it?
16th Aug 2017 10:20pm |
Panda Member Since: 29 May 2015 Location: Essex Posts: 432 |
Where would I find the chassis plate. I have waxoiled the chassis every year since, I have owned it. All the information I have is already on the thread. It's a good bit of kit, I just can't pull her anymore. Everything works just needs a bit of tlc
Thanks Monty-2015 2.2 110 XS Puma Station Wagon Yoda Disco 3-Sold Larry Disco 1-Sold Muddly XS 90 TDCI-Sold Pearl Disco 2-Sold Larry Disco 1-didn't want too but sold |
17th Aug 2017 8:05pm |
johnnyd Member Since: 13 Apr 2013 Location: Chippenham Posts: 1006 |
When you say needs a bit of talc and some welding......how much welding and where?
Also am I right in saying that's a NATO hitch? How much would it cost to change mine to a NATO OOI? JD 2008 TDCi 2.4 XS CSW |
27th Aug 2017 6:04pm |
Hi JD
It's on the front behind the hitch on the tube, be a 5 minute job to weld or can be repaired with a patch. The NATO hitch will bolt straight on to the rear crossmember under the door, so nothing Hope this helps Paul Monty-2015 2.2 110 XS Puma Station Wagon Yoda Disco 3-Sold Larry Disco 1-Sold Muddly XS 90 TDCI-Sold Pearl Disco 2-Sold Larry Disco 1-didn't want too but sold |
27th Aug 2017 7:19pm |
Hi Paul
Not quite sure how it attaches to the rear crossmember directly, do you have any pics? Also is it towable and safe in its current state? I mainly need it for log transferal for the woodburner lol, although I do have an RV3 tent which seems to fit quite well on top I see JD 2008 TDCi 2.4 XS CSW |
27th Aug 2017 8:16pm |
Hi JD
There are 4 bolt holes on the crossmemeber in the center at the top under the door it just bolts directly into the bolt holes. The tent is a RV5, so an RV 3 will fit with no issues, it's totally safe and good to go on or off road. Paul Monty-2015 2.2 110 XS Puma Station Wagon Yoda Disco 3-Sold Larry Disco 1-Sold Muddly XS 90 TDCI-Sold Pearl Disco 2-Sold Larry Disco 1-didn't want too but sold |
27th Aug 2017 8:28pm |
Ah I see what you are saying now from looking at google pics, but I don't have a nato hitch, I have a standard ball hitch if they have a name? are these NATO hitches easy to get hold of and is the height right if it just bolted to the crossmember, I see some pics of them being at an uncomfortable angle on google?
27th Aug 2017 9:21pm |
Hi JD
It works well in that location, runs straight. NATO hitch, I have two. One for a drop-plate set-up (Dixon-bates), the other to bolt direct to the crossmember, with bolts. £40 if you would like one. Cheers Paul Monty-2015 2.2 110 XS Puma Station Wagon Yoda Disco 3-Sold Larry Disco 1-Sold Muddly XS 90 TDCI-Sold Pearl Disco 2-Sold Larry Disco 1-didn't want too but sold |
27th Aug 2017 9:39pm |
SOLD!
Thanks guys and girls for the interest. Monty-2015 2.2 110 XS Puma Station Wagon Yoda Disco 3-Sold Larry Disco 1-Sold Muddly XS 90 TDCI-Sold Pearl Disco 2-Sold Larry Disco 1-didn't want too but sold |
30th Aug 2017 6:53pm |
