Home > Tdi > 300tdi Underpowered? |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1728 |
injectors and pump may need overhaul
Turbo not giving sufficient boost exhaust partially blocked intercooler / hoses blocked / collapsing lift pump on its way out? good luck Keith |
9th Aug 2017 10:16pm |
pj2106 Member Since: 20 Dec 2012 Location: Huntingdon AKA The Shire Posts: 1500 |
Should put a td5 in it 😂😱 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
9th Aug 2017 10:23pm |
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 4940 |
EGR leaking? if you have one on, id bin that off straight away. I found that mine wasn't too keen to pull away, in 1st and 2nd gear. Until I binned the full EGR system off. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
10th Aug 2017 5:50am |
as it should have had a cam belt replaced before you got it, is it correctly timed?
10th Aug 2017 1:02pm |
Tompoole Member Since: 05 Jun 2011 Location: Bucks Posts: 822 |
1. Check the accelerator cable is giving full movement on injection pump 👍
2 check lift pump My bet is someone's hacked cable off to get through MOT Have fun be happy |
10th Aug 2017 4:36pm |
Interlet Member Since: 10 Oct 2011 Location: Norwich Posts: 461 |
Been a while since I got round to it.
I did the boost pin mod, and did that screw up half a turn on the back of the injector pump. Power-wise it's good, although it smokes some under acceleration now...however I have an EGT gauge and and an utterly knackered intercooler - I'm pretty sure it's the original IC, and the view of the fins from the front looks pretty grim. So, I'll keep an eye on my EGT, try not to rag it too much, and save up for a new uprated intercooler. I'm fairly confident that a duff IC will be the reason for some mild to moderate black smoke, so I'm tempted to leave it for the time being. 1998 110 300Tdi White Hard Top |
24th Aug 2017 5:06pm |
LANDROVER Member Since: 13 Feb 2016 Location: EAST OF ENGLAND Posts: 205 |
...TD5 .....Cummins 5.9 |
24th Aug 2017 9:24pm |
I messed with my 200TDI and could'nt get exciting power from it. Some seem better than other. The 300's seem a bit like it too..Some feel like that have a bit more to give than others. EGT...I'm not sure if you can push them high enough to worry? I know people used to leave IC out when doing series conversions. I think they was about 20hp without. Mine rolls coal nicely from low-mid range and a nice grey colour on max boost. |
24th Aug 2017 9:30pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10513 |
Cant beat 'rollin coal ' 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton. |
24th Aug 2017 9:58pm |
I've heard quite a bit around various forums of people turning their pumps up and unknowingly cooking the engine, so I'm a bit cautious. I bought an EGT years ago with the aim of tweaking it a bit, but never got round to it. My EGT before turning it up in this engine has never done much more than 580 which is somewhat low, but then I've been thinking it's gutless for quite some time. The original engine got up to around 630 on long climbs, and felt like it had more poke. After I turned it up a bit, EGT shot to 650 or so, with my foot not even on the floor. 1998 110 300Tdi White Hard Top |
25th Aug 2017 10:38am |
Certainly worth checking EGT as it's easy to install on a 300. Like you say worth being careful and doing the job right if you have issues. Measuring boost and checking turbo condition. A guy I know has messed quite a bit with TDI's for years and just adjust's the Diaphragm and Star wheel under the diaphragm. Also removes the Nylon spacer which affects fuel at boost. I removed mine. He never checks EGT or Boost. He adjust's and drives them until he get's the required power. I've not known him to melt pistons or cook engines before, and he uses max throttle I'm a bit more conservative and don't use full power often. Some have covered a few hundred thou and they tend to get killed by other issues. They all get used fairly hard...bent axles and exciting problems! |
25th Aug 2017 9:31pm |
I know it's great! People always look so concerned I run a straight pipe turbo back no mufflers. Sounds great under load. |
25th Aug 2017 9:37pm |
It is great i have no centre box but have the back box still on 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton. |
28th Aug 2017 9:16pm |
oneten110 Member Since: 02 Jul 2011 Location: Wish I was still in France Posts: 741 |
[/quote] I know it's great! People always look so concerned I run a straight pipe turbo back no mufflers. Sounds great under load.[/quote]
That rather depends upon your perspective |
29th Aug 2017 11:58am |
