Home > Technical > Anyone got any remote reservoir adjustable dampers? |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19599 |
Didn't the very latest 2.2's have something similar? Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
17th Aug 2017 3:00pm |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2075 |
No idea but I can't imagine Land Rover fitting remote res or adjustable shocks to a Defender!
17th Aug 2017 3:52pm |
Dave T Member Since: 07 Jun 2013 Location: Glasgow Posts: 487 |
there are a few in our club that have them, on CCV cars. What exactly do you want to see, may be a week or two until we see some again though 2015 RRS Autobiography SDV6
1994 Def 90 300tdi |
18th Aug 2017 7:18am |
Want to get a look at how they adjust, if thr adjustment knob can be removed and what fitting is under it. Working on a way to see if they can be adjusted remotely/in cab like fancy top end coilovers
18th Aug 2017 9:19am |
100inch Member Since: 15 May 2012 Location: Brunswick Posts: 407 |
You can't remove the adjustment away from the shock body/reservoir as the interfere directly with the oil flow. American brands like Fox do 2.0 entry level shocks with adjusting knobs, but if budget allows have a look at brands like Proflex, Aragosta or Ohlins. They offer 2/3 way external adjustments. m
19th Aug 2017 12:19am |
You can't remove the adjustment valves away from the shock body/reservoir as the interfere directly with the oil flow. American brands like Fox do 2.0 entry level shocks with adjusting knobs, but if budget allows have a look at brands like Proflex, Aragosta or Ohlins. They offer 2/3 way external adjustments. m
19th Aug 2017 12:21am |
Kit Member Since: 12 Feb 2016 Location: Shropshire Posts: 1110 |
King also do great shocks 1993 200 Tdi 90 CSW
1956 Series 1 Hard-top 1958 Series 1 Soft-top |
19th Aug 2017 1:44am |
Click image to enlarge Picture showing one of the 3 Bypass on my 3"King, with the 2.5" Dual Rate Coilover. No adjustments on the reservoir. m |
19th Aug 2017 6:29am |
Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2626 |
I thought the main reason behind remote reservoir dampers was for better cooling?
I really want a set of king or ohilins remote resevoir dampers but they are probably wasted on a road car, ill stick with bilstein for now, |
19th Aug 2017 4:37pm |
Yes, the reservoirs are mainly for the cooling and make shock rebuilds/valving easier too. Did you get a quote for Ohilins?
19th Aug 2017 11:56pm |
i asked twisted about them as they stick them on the v8 builds which im currently on with...
i think it was around the 4k mark + vat... hence why they only use on v8 builds.. |
20th Aug 2017 12:08pm |
Ohilins would be well worth their money but if you want something similar but a tad less expensive Proflex is another great brand. Note that those type of shocks (European Designed) are harder to rebuild and revalve due to having a 'bladder' instead of a floating piston in their reservoir. m
21st Aug 2017 1:13am |
