Home > In Car Electronics > Fitting Parking Sensors NAS Rear Step |
Def90 Member Since: 17 Jan 2015 Location: Kent Posts: 253 |
Hi Stiff1
Answers to your questions You can get the cross member cover plate from here. http://www.landrovertrailair.co.uk/products/ The modified folding step is just fitted with bolts onto the under side of the NAS rear step. Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge No tow bar fitted at present but you can remove the additional folding step and fit a one without any issues. The bracket on the right hand side is the lower mounting point for a spare wheel carrier that I hadn't re fitted when the pictures were taken. Covers for the small holes in the cross member are just closed or blind blanking grommets from eBay or any good auto electrical supplier but I'm still trying to find some 18/19mm ones to suite the two centre holes. |
6th Aug 2017 8:46am |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2073 |
Thought I'd share a few pics now I'm finally done with the sensors!
Mounted in the jack mount, looks the neatest and safest for the sensor Click image to enlarge Others mounted inside the chequer plate/rear corner, again quite protected but still useful Click image to enlarge Switch so I can turn them off when off road Click image to enlarge |
17th Aug 2017 10:31am |
Stiff1 Member Since: 09 Dec 2014 Location: Cornwall Posts: 574 |
Nicely done, like the switch.
17th Aug 2017 4:26pm |
