Home > Maintenance & Modifications > Corrosion Prevention Guide! |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 4990 |
Grind, wire brush, sand paper back etc rust.
Treat with Dinitrol Converust RC900 aerosol. Then a layer of Dinitrol LT (penetrant cavity wax to help adhesion) aerosol. Then a final layer of Dinitrol 4941 Underbody Wax aerosol. Supplied by Rejel.com. It will probably be about £35, the Converust and LT should last you a while and you may want a can or two more of the Underbody 4941 depending on how much you want to treat. Don,t forget to keep on top of your body treatments with ACF-50 with all the hidden bare metal beneath cappings and between fixed surfaces these are equally important and will rot a lot quicker than your chassis. Have fun Just to add, VERY important, get a proffesional mask with all the correct filters, especially for the Converust, you will be coughing up phlem in the morning from acid damaged lungs. Holding your breath and running away doesn,t cut it, nor do cheap masks or paper masks. Sadly even professional masks do not completwy protect you from the various products, my lungs are damaged long term, it,s part of the job similar to body shop paint sprayers. Converust is especially lethal! Protectivemasksdirect.co.uk sell a range of masks full or half face. Roughly £70-80 depending on choice of mask. If half face wear goggles with the Converust! You will need Moldex P3R 9030 filters Moldex 9400 EN 14387 filters which have four types of filter in one cartridge called A1,B1,E1,K1. |
7th Aug 2017 7:37am |
5wh Member Since: 01 Jan 2011 Location: Lancashire Posts: 37 |
Ok - thanks for the info.
This job sounded straightforward but it sounds like it's best left to the professionals! Any recommendations for anyone in Lancashire who could do this? 2009 SVX 90 Station Wagon |
8th Aug 2017 12:47am |
Don,t let me put you off, just rub back rust, then Converust, LT and 4941 allow to dry in between each spray.
Check out 'Waddies' Hymer camper in my gallery I did yesterday, a very nice TDI and a Twisted 90 I have in at the moment. I have forgotten how to pics up on a post from the gallery already |
8th Aug 2017 8:11am |
Culminator Member Since: 30 Apr 2013 Location: West sussex Posts: 305 |
Thanks Chris for working your magic on my truck. All looks great, proper job.
10th Aug 2017 10:29pm |
Pleasure Mike
14th Aug 2017 9:30am |
greenlandrover Member Since: 09 Jul 2017 Location: Stourbridge Posts: 145 |
Just booked my slot to get the Zagato treatment on 30th Oct 👍🏻
23rd Aug 2017 8:40am |
JeremyJ Member Since: 16 Nov 2011 Location: Aylesbury Posts: 1758 |
Massive thank you to Chris for a great job on my 110, very very impressed!
26th Aug 2017 2:06pm |
SuneP Member Since: 25 Aug 2017 Location: Fyn Posts: 5 |
Is there a chance and updating the pictures for can not see them
Thanks. |
10th Sep 2017 10:37am |
12th Sep 2017 2:17pm |
Peakwayfarer Member Since: 24 Jul 2017 Location: Peaks Posts: 1 |
Hi Chris
Just a quick note to say thank you for the great job you did on my Discovery 4 last week, whilst we enjoyed a days exploring the Sussex countryside. A long way to travel from the Peak District but worthwhile to get the job done thoroughly All the best Phil |
23rd Sep 2017 9:24pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6485 |
I have recovered and re-hosted the images from this thread 1988 90 Td5 NAS soft top
2015 D90 XS SW |
11th Oct 2017 9:51am |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7875 |
Fantastic, thanks Martin, much appreciated! James
11th Oct 2017 10:05am |
MudHugger Member Since: 17 Jan 2016 Location: Essex Posts: 28 |
Great thread and very informative, must get my defender treated.
17th Oct 2017 8:18am |
Brilliant, thanks Martin |
21st Oct 2017 1:08am |
