Home > V8 > V8 ENGINE MODS AND EXHAUST |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10360 |
Rimmers do stainless sports exhausts.
5th Feb 2017 4:32pm |
nicam Member Since: 14 Dec 2007 Location: deepest Lancashire Posts: 156 |
Put the full SS system including tube headers on my V8 90 and the difference it made was amazing - it would pull a gear higher in most situations. I put it down to the restrictive original manifolds mostly.
Well worth it! Don`t drive faster than your angel can fly! |
23rd Feb 2017 9:11pm |
Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3753 |
A set of headers to start with, and then a free flowing big bore exhaust, if you're going the single pipe way, 2.5" should do the trick.
HOWEVER, and from the land of V8s, I don't see many of you guys doing this, the "classic" V8 exhaust is twin pipes, coming out either side of the rear of the vehicle. Pickles. |
23rd Feb 2017 10:22pm |
VVS210 Member Since: 12 Nov 2016 Location: Hampshire Posts: 953 |
Janspeed...
Tubular headers & big bore performance exhaust. |
23rd Feb 2017 10:40pm |
Blanc Member Since: 14 Jul 2016 Location: Suffolk Posts: 43 |
Has anyone here who has fitted tubular headers also installed heat wrap on them?
I've just fitted some (Rimmer Bros) and am worrying about heat. Thanks David |
2nd Mar 2017 10:51pm |
Kernow90 Member Since: 22 Jul 2017 Location: Cornwall Posts: 3 |
I've got stainless tubular on mine and don't get any problem with heat , just beneath of where your starter motor cable runs that's all
22nd Jul 2017 11:00am |
Click image to enlarge I wrapped mine. But I'm going to add more vents to the bonnet when the v8 comes off the road in Autumn. |
22nd Jul 2017 4:54pm |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1746 |
My 110 with Gems V8 has a 50th Anniversary y section with CATS, then a 300tdi Centre silencer Removal pipe and 300tdi 110 rear section. So only silencer is on the tailpipe.
Works well |
22nd Jul 2017 6:08pm |
need4speed Member Since: 23 Nov 2012 Location: Kilmarnock Posts: 746 |
Sorry but I really need to weigh in here.
Most of the tubular manifolds available off the shelf for the RV8 are absolutely terrible. Mainly because most were actually designed for sports cars that want most of the power gain at higher rpm. Hence the 4 into 1 design. The only ones worth considering are specifically designed manifolds that put the power where you want it on a defender i.e. Low to mid range rpm. This requires manifolds that are 4 into 2 into 1. In reality the cast twin-port disco v8 manifolds are very good indeed. 4.6 RV8 110HT |
3rd Aug 2017 6:20pm |
100inch Member Since: 15 May 2012 Location: Brunswick Posts: 407 |
John Eales has the ported cast manifolds back in stock according to my knowledge but I guess pricewise they are not justifiable on a non race engine... What ever manifolds you get have them ceramic coated instead of wrapped. Wrapping can burn if you got a heavy oil spill. m
5th Aug 2017 10:47pm |
oneten110 Member Since: 02 Jul 2011 Location: Wish I was still in France Posts: 741 |
For what it is worth I had a double s system on mine and it was an absolute pile of junk. It is not intended for the 110 but for a range rover. Thus there is an additional section of pipe between the Y pipe and centre box which was continually working loose, the tubular manifolds were a dreadful fit on the heads, a poor fit on the Y pipe and the welds on one of them cracked. The tail pipe came out right where the rear mud flap is fitted and they weren't even remotely interested in doing anything to remedy the situation.
Currently I am running Range Rover cast manifolds, Range Rover 2-1 pipes, a Range Rover Y pipe, 300 Tdi middle box and a plain tail pipe without the resonator. Sounds nice without being gobshyte loud |
20th Aug 2017 3:03pm |
