Home > Puma (Tdci) > VCV change.. Don't know what all the moaning is about!! |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 |
Now change one on a 2.2.... 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered. |
26th Jul 2017 7:16pm |
dilukabey Member Since: 17 May 2011 Location: Sri Lanka Posts: 173 |
Hi. I want to do the pilot relearn after the vcv change. But need to get the injector coding. My be this is a stupid question.is it same coding for all 2.4 puma if so what are the four codes? Cheers.
29th Jul 2017 6:11pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16916 |
The codes are unique to you vehicle but unless you change an injector or the ECM you shouldn't need them. For a VCV change you don't need to do an injector relearn, just the pump.
29th Jul 2017 6:50pm |
Hi Blackwolf. Yes I did the pump relearn then many of the problems solved but still get the engine clatter when the engine is warm. So I thought of doing it and see. Any idea? Cheers
29th Jul 2017 6:59pm |
M94PUMA Member Since: 16 Dec 2016 Location: Hampshire Posts: 105 |
Have you done the pilot correction learning procedure as well?
Even with the fuel pump learn and pilot correction not "synced" the engine should not be clattering. Suspect you have further issues than just the vcv, injector knock?? Maybe a new set of injectors or get yours tested? |
30th Jul 2017 9:50am |
Yes I have done pump relearn after vcv changed. But not the pilot correction yet. I had to romove all the four injectors long time ago to replace the copper washers and cleaned and fitted them back. But never done a pilot correction.
Today I managed to read the 16 digit injector codes in my puma and the first three found to be identical. I hope I read them correctly. These are the values I got. 1st injector F4000000000000F4 2nd injector F4000000000000F4 3rd incjector F4000000000000F4 4th incjector F400000C00000BF3 Can this be possible? |
30th Jul 2017 10:31am |
