Home > Td5 > TD5 cruise control kit |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 |
so if you used D2 ecu then it should be programmed for the higher TB? |
1st Feb 2011 11:18pm |
Zinke Member Since: 27 Jan 2009 Location: Scunthorpe Posts: 670 |
Yes in theory that would work, but ive not been able to get a discovery ECU to work on a defender yet. You can change the drive gear for the speedo in the transfer box to fool the ECU into thinking that the vehicle is going slower that it is but then your speedo is reading way under what it should and the mileage would be low too. Think its about 15% low. The only true fix would be to see if somebody like Pete from BAS can make a map that would accept the disco transfer box and allow the cruise to work too. But ive been told its not something that can be does easily. Pete. |
2nd Feb 2011 8:33pm |
Roald Member Since: 31 Dec 2010 Location: Aarhus Posts: 31 |
Can someone recommend me a kit? I have only found the cruise kit http://www.nakatanenga.de/ sells, is that a good one?
13th Mar 2011 9:26pm |
Nice. Is your installation guide only in German or? |
14th Mar 2011 8:08am |
nakatanenga Member Since: 12 Nov 2010 Location: Neumarkt Posts: 546 |
In english as well!
The D2 transfer speedo adaptor comes with a drawing which can be understood. WANTED: SII or SIII in max 1.5k |
14th Mar 2011 10:55am |
ben_j85jty Member Since: 03 Sep 2008 Location: Bicester, Oxfordshire Posts: 491 |
Interesting,
Does it work with D1 boxes as well? 2002 Defender 110 DC |
14th Mar 2011 1:32pm |
To be honest, the device is a frequenzy divider, multipler.
It changes any input signal to different output signals. So it can change speedo signals as well as revs or any other pulse. We use it with Td5 and Pumas with extreme tire sizes to the correct speedo settings. WANTED: SII or SIII in max 1.5k |
14th Mar 2011 9:54pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6041 |
Couldn't find it in English on your site at all.... got a link???
14th Mar 2011 9:59pm |
http://nakatanenga-tours.de/shop/article_T...5201000%26 WANTED:
14th Mar 2011 10:03pm |
megatoad Member Since: 07 Jan 2012 Location: Hertfordshire Posts: 358 |
Hi Zinke
Not sure if I alread sent you a pm this morning, but I was wondering if you are still doing the cruise control kits for the TD5, mine is an 06 with standard tyres and transfer box so should be OK Do you crimp the terminal connections for plugging into the ECU connector? I am seriously toying with the idea. Julian He who dies with the most toys wins Defender 90 & 110, S1 80", Disco 1, S111 88 LRSOC & CVLRC |
1st May 2013 2:35pm |
Postmanpat Member Since: 01 Aug 2012 Location: Co.Limerick Posts: 50 |
where can one get it ? Postmanpat |
21st May 2013 10:57am |
