Home > Maintenance & Modifications > Side steps, what do you have?
Mine will need replacing shortly.
What do you have? I currently have CP ones at the moment that the previous owner fitted.
I'm not sure I want them again and quite like the I.C.E. style.
What do you think works nicely with CP sills?
Not really looking to go for black tread plate unless it's just rubber grip. NEVER SURRENDER! ⛽️🛢️👨‍🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
Post #635667 4th Jul 2017 10:28pm
the gamekeeper
England 2007 Defender 110 Puma 2.4 DCPU Tonga Green
Fold ups, that stay folded up and collect muck Cool
Post #635668 4th Jul 2017 10:33pm
Pickles
On our '13 90 we have the factory option black tube item with silver chequerplate
Pickles.
Post #635670 4th Jul 2017 11:07pm
CarMan
Genuine, retro fitted by me Thumbs Up
 Rob
1993 200tdi 90 hard-top
1998 300tdi 90 soft-top
2016 2.2 XS 90 hard-top (sold)
Post #635691 5th Jul 2017 6:11am
BCdefender
Canada 1999 Defender 110 Td5 CSW Orkney Grey
I ended up going with the galvanized terrafirma rockslides/tree guards and had them powder coated. Also put on grip taped to avoid the tibia impaction fracture! These seemed like the best option because they don't affect clearance. 1999 Defender 110
2003 P38
2007 RR SC
"And that's why it needs to be celebrated, because when the Defender goes we'll have lost this pointer to where we came from, and we're really going to miss it."
My build thread: http://www.defender2.net/forum/topic47750.html
Post #635692 5th Jul 2017 6:17am
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Stainless tubular on mine, not much of a step but at least they don't rust like the originals Shocked
 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #635697 5th Jul 2017 7:14am
ericvv
Post #635721 5th Jul 2017 9:00am
Oakseywick
United Kingdom 2000 Defender 90 Td5 XS CSW Java Black
Stainless steel twin tube on the 90, replaced the rusted out black version that it had on it and fire and ice style on the 110
Post #635722 5th Jul 2017 9:11am
bankz5152
Dixon Fabrications tubular rock sliders, coated in Raptor & sand for grip.
I wouldnt fit anything else tbh the added side impact protection for on road driving alone is reason enough
Post #635724 5th Jul 2017 9:13am
discomog
Ian series 1. I do like your stainless "steps". Did you have them made or were they off the shelf? Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #635747 5th Jul 2017 12:45pm
ian series 1
Off the shelf. Thumbs Up
https://www.googleadservices.com/pagead/ac...amp;adurl= 80" 80" 86" 88" 90"
Post #635749 5th Jul 2017 1:09pm
agentmulder
Kuwait
None 👍 Solved the bowel problem, working on the consonants...
Post #635880 6th Jul 2017 6:39am
Think I will be looking at the version the same as Carman has, Genuine.
Pricy though as per LR but seem pretty good.
I'd be inclined to drill a small hole in the plastic end caps, and tap a thread and use a Stainless fixing as a removable cap to use Dintitrol internal wax on and off.
I can see the merits of stainless, but I don't like bare stainless and the rest is mild steel but painted so that isn't a problem to me.
Time to put the pennies away, lots of them by the looks of it. Shocked Laughing NEVER SURRENDER! ⛽️🛢️👨‍🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
Post #636266 7th Jul 2017 7:37pm
Pickles
We optioned the factory side steps on our '13 Puma 90,..option "048AP".
There is some confusion as to what actually are the correct items as there are some that look somewhat the same, but aren't.
In view of some comments & images that I've seen on this forum regarding durability etc, I bought myself a spare set, which couldn't be bought as a set, only individually.
The part numbers are LR029295(RHS) & LR029297(LHS).
I also bought the supporting struts.
Not cheap.
Pickles.
Post #636319 7th Jul 2017 11:29pm
