Home > Technical > Numberplate Light Plinth |
I can't really think of a reason for it to be there in the UK.
Perhaps in some countries where they don't have the large square plates and use small rectangular ones (US, Japan for example) it's needed to throw the light further down the body. Certainly in the UK i don't see any reason you couldn't lose the spacer. |
7th Jun 2017 1:42pm |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3696 |
Handy for fitting a camera in
Click image to enlarge |
7th Jun 2017 2:01pm |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7875 |
Interesting question, often wondered why it sticks out so far. James
7th Jun 2017 2:49pm |
I took my spacer off years ago and it still all works fine and the plate is still lit up. Ray
7th Jun 2017 3:52pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19647 |
You can do without it completely if you wanted. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
7th Jun 2017 5:34pm |
V8GPC Member Since: 18 Jul 2016 Location: Manchester Posts: 289 |
When I fitted an LED version the cable exit was in a different place to the hole in the body.
I turned the plinth around; drilled a new hole to line up with the LED and then the cable had a nice void to realign with the body... so came in useful in the end. |
7th Jun 2017 6:58pm |
Butchers Boy Member Since: 10 Jan 2016 Location: Essex Posts: 426 |
Really handy for fitting a rear view camera in 2010 Defender 90 HT
The longer I live..... The better I was! |
7th Jun 2017 11:50pm |
