Home > Off Topic > House Refurb
DarrenJ
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
House Refurb
Im just about to do my mums house up and wondered if i need to notify the council of any work that is being undertaken.
It is having
1, complete re-wire (will be signed off my electrician under Part P)
2, all new windows installed and FENSA certificated
3, bathroom fitted into the old kitchen.
Darren Darren
Post #623888 13th May 2017 7:22pm
David T
United Kingdom 2012 Defender 110 Puma 2.2 USW Santorini Black
No, unless it's stood empty for a while with no services and you want a council tax "holiday"
dt
Post #623890 13th May 2017 7:33pm
ickle
strictly changing any room into a bathroom is notifiable to the council for building regs approval.
Post #623892 13th May 2017 7:53pm
JOW240725
I think that would be notifiable, due to the extent of the work, but best give building control a quick call for confirmation. James
Instagram @suffolk_rovers
Post #623900 13th May 2017 8:18pm
mse
If you have trades to certify the bits you do not need to notify building control, as the trades are certifying it.
If you are doing the work yourself, then you can notify building control to enable you to do the work, same as if you got trades to do it...but who aren't certifying it. Mike
Post #623902 13th May 2017 8:28pm
This is true. Contractors can't self certify this sort of work.
The other stuff is essentially maintenance and can be signed off in the way that you describe. Darren
Post #623905 13th May 2017 8:36pm
David T
No it is'nt, unless in a listed building.
Post #623944 13th May 2017 10:29pm
corgi1
England 2009 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Sorry to disagree people, I do this kind of thing quite a bit, if your changing kitchen to a bathroom- inc a toilet you must contact building control, they will want to see where you break into the sewer before they sign it off, but if your not going to sell it you will get away with it, if in the future you sel it don't mention it, and no one will be the wiser, the other stuff as you all say can be signed off Mr. Green
Post #623959 14th May 2017 12:41am
David T
One thing is for certain, in the time it takes to argue the toss on here you could put in for planning permission, build an extension, put the house on the market, sell it and purchase a place in Tuscany using Silvio Berlusconi's legal team.
Best of luck with it all.
You can check the Gov. planning portal, btw.
Post #623974 14th May 2017 6:29am
DarrenJ
Cheers for all the advice, as there is already waste in the room i didn't think id need but I keep getting mixed messages.
There is no intention to sell but purely to make it more habitable for my mum by making the old bathroom as an ensuite wet room.
Cheers again
Darren Darren
Post #623982 14th May 2017 8:49am
Darren, if you're not sure then the best course of action would be to give your local building control dept. a call and ask. In my experience, building control are usually pretty pragmatic and helpful (unlike planners...). Darren
Post #623991 14th May 2017 9:18am
languedoc
Scotland 2008 Defender 110 Puma 2.4 CSW Alaska White
As an ex chartered surveyor, you need warrants for relocating bathrooms. You can do this later with retrospective permission if you come to sell or do it now.
Any buyer will use a surveyor and they should report changed layouts and this will then require a follow up by the solicitor on behalf of the lender.
Windows also need to be up to escape standard depending on your local authority but just keep the spec and paperwork which will be fine.
Post #623994 14th May 2017 9:39am
mse
There is a website from LABC that takes you through all of this.
Breaking into a sewer isnt the problem - its load bearing weights on the wall for the bathroom
As a point - you dont need building control - you need a building inspector, which could be the local authority but can be a private inspector - Building control is the only area where its a statutory requirement (if needed) but isnt the sole LA responsibility.
https://www.planningportal.co.uk/info/200128/building_control
https://www.planningportal.co.uk/info/2001...egulations Mike
Post #623996 14th May 2017 9:49am
ginjez
2011 Defender 90 Puma 2.4 ST Santorini Black
I hope there are no planners on here but you are quite right. LABC are an absolute pleasure to deal with as long as you are straight with them. Pick up the phone and have a chat with your local officer. I deal with them weekly and would not even consider a private company for inspections.
Post #624129 14th May 2017 7:40pm
familymad
Spark completing correct and relevant paperwork will notify Council
Fensa will do the same as above
Yes, new bathroom requires building regs approval not planning. Can do it on a building notice yourself though. 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #624138 14th May 2017 8:01pm
