Home > Puma (Tdci) > Hot hand brake
Stephan
Namibia 2008 Defender 130 Puma 2.4 HCPU Alpine White
Hot hand brake
All,
Does any of you had experience or heard of hand brake handle getting so hot that it can not be hold?
On my 130 2008, when i drive more than 40 km and at sustain speed (100 to 110 km/h) the hand brake handle start to be so hot that my left leg (RHD) sustain a few burn already.
Any experince is welcom. The dealer did mentioned a similar problem with TD% due to earthing problem on other vehicle. Stephan
Meiring II - 130 Puma 2008
Meiring I - 110 200TDI 1989/1991
Post #5854 2nd Jan 2009 6:52pm
Sticky
England 2016 Defender 130 Puma 2.4 HCPU Stornoway Grey
Definately not the case on mine, I would notice when I wear shorts, as I am sure, like everyone myleg sits against the handbrake lever.
I would get it checked again!
Post #5855 2nd Jan 2009 7:06pm
Eduardo
Not on mine also Eduardo
Post #5857 2nd Jan 2009 8:00pm
dave's 110
United Kingdom 2008 Defender 110 Puma 2.4 DCPU Stornoway Grey
Hi Stephan
that a look at my other post on this on here http://www.defender2.net/forum/topic360.html?highlight=
Dave
Post #5899 4th Jan 2009 4:15pm
Stephan
Hi Dave,
Thanks for the info. I will check with my dealer tomorow. Stephan
Post #5905 4th Jan 2009 5:58pm
jst
only when the heater is on 'feet' and set hot and fan on 3! Cheers
James
110 XS Utility
130 Puma Station wagon/camper (in the making)
90 Puma Hardtop
Post #5911 4th Jan 2009 6:26pm
TJ101
Yep, also had it on mine,, long Motorway run, after 30.40 mins,,
Try it with the window closed,, with it open, the air/heat get dragged up through the seat box !! California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #5919 4th Jan 2009 7:21pm
Bundubasher
South Africa 2007 Defender 110 Puma 2.4 SW Chawton White
Hello Stephan. The same thing happened to me when I drove to Kruger park in october. I was a bit concerned at first but the next day it was cool when I was driving around the park. I think the problem that we both have is that our roads radiate so much heat in summer and when we drive at a high speed the heat radiates from the hot road surface and the whole transmission system gets so hot that the heat eventually radiates to the hand brake lever etc. I hope this helps.
Regards
Anthony
Post #6064 8th Jan 2009 5:48pm
The Boy
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Rimini Red
Hi stephan
Yes happened to me whilst coming back form the Alps . Popped the seals on the transfer box too.
Look at my last post here http://www.defender2.net/forum/topic784-15.html
Post #6065 8th Jan 2009 6:28pm
Stephan
Dundubasher,
Thanks. I do think there is something to do with heat (road or ambient) I have seen that if the ambient temperature is below 25 C then the hand break does not heat up. Not sure if it is radiant heat or expensiontion and tolerance playing up.
Stephan Stephan
Post #6211 12th Jan 2009 1:59pm
