Home > Technical > Replacing Rear Diff Oil Seal on a Salisbury Diff |
g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967 |
i think you leave the crush tube!. mark the nut and count how many turns to get it off. then when you re-tighten, turn it same number of time and that should be it.
someone with actual experience of doing it should be along shortly to confirm! My 109 thread my youtube channel |
24th Apr 2017 10:22am |
thompjas Member Since: 07 Mar 2014 Location: Northants Posts: 36 |
This of course assumes that the curent 'nut' was put back in place correctly !
I have a lot of free play before the rear diff moves any rear wheel..... |
24th Apr 2017 11:39am |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2199 |
If you are unsure, it might well be worth replacing the crush tube and torqueing the nut according to the workshop manual procedure.
That way you wont end up reassembling it to match previous other mistakes. I have never seen a Salisbury diff which did not have quite a substantial amount of backlash however. Steve 02' 110 TD5 Double Cab Rebuild Thread 84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale Mobile Diesel Heater Build Thread |
24th Apr 2017 12:18pm |
