Home > For Sale & Wanted > [For Sale] Alive tune box |
90def Member Since: 11 Apr 2011 Location: bedfordshire Posts: 98 |
Alive tune box atric with lead 100 ono
8th Apr 2017 4:07pm |
Disco_Mikey Member Since: 16 Nov 2014 Location: Dundee Posts: 531 |
The Atric box is the best DIY option for remapping
You buy a map from Alive, and can install and remove the map at your leisure/pleasure Not to be confused with a "plug and play" Tuning box |
8th Apr 2017 5:16pm |
arran jones Member Since: 21 Nov 2016 Location: south west Posts: 725 |
OK thanks, don't worry then, I would love to buy it, but don't really need a alive remap,
Sorry |
8th Apr 2017 5:32pm |
I am thinking of tuning my TDCI pick up (2.4), Would a proper ecu remap be better or would a plug and play tuning box be better?
Thanks |
8th Apr 2017 6:05pm |
Plug and play are a remap is best .Google plug and play .and remaps the box was 500 alive charge 150 to put a map on the box . You can put it back to standard for warranty work
8th Apr 2017 7:00pm |
Leviathan Member Since: 24 Oct 2015 Location: Staffs Posts: 247 |
You have a pm 90def.
8th Apr 2017 7:06pm |
OK thanks
8th Apr 2017 7:43pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19657 |
Well worth it.
Alive Stage 1 approx 150hp, no mods required unless you go to a higher tune. This is an interface to flash a map onto the ECU or return to stabdard map. It also reads fault codes too. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
8th Apr 2017 8:32pm |
Capt_Steve Member Since: 10 Jan 2012 Location: Ross on Wye Posts: 39 |
Does this only work on the 2.4?
9th Apr 2017 10:00am |
Its on my 2.4 60 plate not sure if they are the same on a 2.2 .phil
10th Apr 2017 11:28am |
Thanks mate, I will do some research and get back to you.
Cheers Steve |
10th Apr 2017 10:30pm |
Ask Gary @ Alive. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
10th Apr 2017 10:43pm |
cheers Steve
10th Apr 2017 10:53pm |
Williamraff Member Since: 19 Mar 2017 Location: Leeds Posts: 40 |
Will this work on a 2006 Td5?
Thanks, Will. |
10th Apr 2017 11:38pm |
