Home > Td5 > Central locking issue - 110 n/s/r door
AJC
Hi folks, my nsr door on the 110 will lock on CL but not unlock, I fiteed a new actuator at weekend and this hasn't helped.
The door pin moves upwards when unlocked but not all the way, can anyone suggest what may fix this? Thanks
Post #614669 5th Apr 2017 1:53pm
It's likely to be either wear or resistance in the linkage or the lock itself. As a first step, I'd give the lock a good blast of your favourite aerosol lubricant, work it in a bit and see if that cures it. Darren
Post #614673 5th Apr 2017 2:13pm
AJC
Thank you, I did do that prior to building the door car back up, ill see if lubing up the door lock pin helps.
Post #614682 5th Apr 2017 3:47pm
Intercept
United Kingdom 2002 Defender 110 Td5 Black LE Java Black
Have a look at http://www.defender2.net/forum/topic52876.html My problem was on a front door but the mechanisms are similar.
John
Post #614687 5th Apr 2017 4:29pm
AJC
Thanks John, that looks about right what I need, is that just a bit of elastic rope, trying to think where I can get some from.
Post #614693 5th Apr 2017 4:58pm
lightning
Make sure that the actuator is adjusted properly.
So that the solenoid can operate through its full range when locking/unlocking.
Post #615013 6th Apr 2017 9:53pm
