Home > Technical > ??? What Has Gone Wrong???
Stiff1
So driving on duel carriageway yesterday, approaching roundabout, went to change down and clutch peddle chose to remain on the floor.
Managed to get round the roundabout without stopping and pull into safety.
Cylinder seems to have required level of fluid, no recent works done and no leaks underneath but peddle inoperative and stays on floor unless lifted no then still no sense of engagement.
This is on a 2007 2.4 110 CSW.
Ideas please.
Post #613969 2nd Apr 2017 11:44am
mk1collector
Maybe seals inside master or slave given out, letting fluid past but not out Ray
My build thread
Post #613970 2nd Apr 2017 11:48am
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Any fluid leaking from the bottom of the bellhousing?
Or anywhere else, pedal box, or drivers floor mat? 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #613974 2nd Apr 2017 12:42pm
sharkey964
France 2007 Defender 90 Puma 2.4 XS CSW Santorini Black
Could slave cylinder rod have pushed through the clutch fork???
Marc
Post #613980 2nd Apr 2017 1:27pm
AndyB
1989 Defender 90 300 Tdi HT Cairns Blue
Mine was about to go. (I had pulled the box off due to another issue)
I dont know the 'real' age of our drivetrain, as it was from a Disco, so yours may be different. (just edited this in)
Andy
Post #613983 2nd Apr 2017 1:30pm
mk1collector
I thought they replaced the later ones with solid forks but I may have dreamt it Ray
My build thread
Post #613990 2nd Apr 2017 1:48pm
NickEJ
Slovenia 2004 Defender 90 Td5 XS CSW Galway Green
I had exactly the same problem a few years ago whilst touring in Germany. Needed a new master clutch cylinder.
Post #613997 2nd Apr 2017 2:03pm
zsd-puma
The Puma's don't have a fork at all, they have a concentric slave cylinder.
Sounds like the master cylinder has failed to me, it's an old design, basically the same one used on series 3's and various other 60/70's era BL products. They're not unknown to fail unexpectedly
Post #614008 2nd Apr 2017 2:54pm
Stiff1
Initial thought was the fork from memories of the 300 but a quick search showed up that change.
No fluid to be seen after a good look around.
Post #614014 2nd Apr 2017 3:32pm
defender9
United Kingdom 2015 Defender 90 Puma 2.2 SW Keswick Green
happened to me, was getting intermittent clutch pedal going to the floor, it was the master cylinder seals.
Post #614083 2nd Apr 2017 7:31pm
Stiff1
Where you able to change the seals or is it a new cylinder?
Thanks for all the tips so far.
Post #614088 2nd Apr 2017 8:17pm
zsd-puma
Given you can get branded after market ones for £25 i wouldn't bother messing about changing seals.
Post #614101 2nd Apr 2017 8:49pm
agentmulder
Kuwait
Mine did the same, changed master myself, worked for a week then back to the floor.
Changed slave at shop, which is a much bigger job so changed clutch while in there. Problem solved.
Lots of prior discussion in the forums.. Solved the bowel problem, working on the consonants...
Post #614103 2nd Apr 2017 8:54pm
dgardel
Italy
No fork on TDCi, but the co-axial slave direct on the clutch plate Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #614158 3rd Apr 2017 8:45am
zsd-puma
When the master fails all the muck from the failed seals ends up in the slave cylinder when you bleed it out, so it then kills that too.
I think half the problem is while Brake fluid tends to get replaced or at least tested every couple of years, the only time clutch fuild gets changed is when something fails.
Post #614229 3rd Apr 2017 3:03pm
