Home > Technical > Can you fit a TD5 rad & Inter cooler on a 300tdi |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2072 |
Yes friend of mine has fitted a TD5 full width intercooler to his 300tdi, standard rad though. So bit of work should fit!
23rd Mar 2017 1:22pm |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2079 |
Anything could be made to fit but why would you ?
Mo The Land Rover 90 - Many are called, few are chosen. |
23rd Mar 2017 1:41pm |
A full size TD5 one is what 4x times bigger than the 300tdi one? Denser air, higher boost, more torque, less smoke
23rd Mar 2017 1:53pm |
Sure but it's also thinner and the cooled air has to travel further through a hot engine bay. The Land Rover 90 - Many are called, few are chosen.
23rd Mar 2017 6:47pm |
What? A full size TD5 IC is covers the majority of the front grill and sits infront of thr rad. Its literally the first thing bar the grill to hit the air.
24th Mar 2017 10:28am |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7687 |
internally i dont believe there is much difference between volume of a tdi and puma/td5 intercooler. i looked at this a few years back.
with fitting the td5 inter you will need to rejigg pipework to bring it back across from drivers side to the inlet/turbo compared to std 300tdi Cheers James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
24th Mar 2017 12:28pm |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3346 |
Also remember the Tdi Radiator has an oil cooler built into it which you will loose if you change to a Td5 Radiator.
If it was me I would fit a double thickness intercooler from someone like Allysport or bas tuning. I'm not convinced of the need though, a good running Tdi has enough power for most things Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter |
24th Mar 2017 1:47pm |
i think Mo means the pipework has further to go across a hot engine bay here rather than location of the IC wrt to the post below his. Cheers James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
24th Mar 2017 3:05pm |
Dieselhead Member Since: 21 Oct 2012 Location: Pulborough. West Sussex Posts: 552 |
Thanks for the replies guys
It only crossed my mind & sure it could be done. I had a 300 tdi 110 years ago & that went very well for what it was & was standard Chris 2008 XS 110 2.4 Utility. Tonga Green 1953 Series 1 for restoration 1983 Mini Mayfair 2004 VW T5 Camper 2008 Diahatsu Sirion. Thats hers Classic Bolens Garden Tractors |
24th Mar 2017 7:08pm |
