Home > Maintenance & Modifications > Rusty Bulkhead strip and rebuild
Jim G
United Kingdom 1984 Defender 90 300 Tdi HT Stornoway Grey
Finished the seat box, So now onwards and upwards... The Bulkhead !
What a mess !
 1984 300TDi hardtop Stornoway Grey
1984 200TDi hardtop..... soon to be a V8 .. but which V8 ?
1974 DAF T244 4x4 wagon converted to a motorhome
1976 Jaguar XJC with supercharged engine
Post #611471 22nd Mar 2017 9:10pm
Jim G
The landie ( with 9 months MOT ! ) came with some repair panels 'placed ' in position
the galvanised ones in the photo
Obviously a pattern part.... total rubbish ! holes in wrong place and made of 0.7mm steel !
So made up a couple of plates in 1.5mm steel to weld in, bare metal ones in picture
Then I had to drill some square holes Laughing in them for the plastic jobbers for the mounting screws,
and then cut out the old steel , leaving a nice flange to weld to
Then trim till the repair sections fit , ready to weld tomorrow !
Going to have to fab up a side panel as well, or it might be a bit draughty.
Post #611478 22nd Mar 2017 9:20pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
Good metal bending skills, keep up the good work. Thumbs Up 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #611482 22nd Mar 2017 9:25pm
Jim G
Welllll............. actually had the local metal shop cut and bend them, my Clarke bender isnt up to it !
Embarassed 1984 300TDi hardtop Stornoway Grey
Post #611487 22nd Mar 2017 9:30pm
Jim G
I lined everything up, drilled some holes to weld through, and used bolts to temporarily hold it in position ready for welding
Looking better already 1984 300TDi hardtop Stornoway Grey
Post #612056 25th Mar 2017 6:38pm
Jim G
Started today with some KAD....
Kellogs aided design !
Rolling with laughter
Let the welding begin
Some strenthening on the floor , dont think it is neccicary
Floor all finished, quite pleased with the result, considerably stronger than the floor in my 300TDi
Now just the other patches to do.... 1984 300TDi hardtop Stornoway Grey
Post #612273 26th Mar 2017 4:46pm
Outlaw1
England 2010 Defender 110 Puma 2.4 USW Santorini Black
Nice work Jim
Have you tried the frosty KAD system in the winter months
Post #612293 26th Mar 2017 6:36pm
Thon
Always pleasing to see some well-executed fabrication Thumbs Up
For fabrication junkies these guys are brilliant ...
http://www.badobsessionmotorsport.co.uk/ca...ect-binky/
Top fabbing Mr. Green
Post #612321 26th Mar 2017 7:56pm
Jim G
Yes, been watching the series, those guys are amazing, and such well executed video ! 1984 300TDi hardtop Stornoway Grey
Post #612360 26th Mar 2017 9:33pm
Thon
I think the effort they put into fabrication is matched by that put into their production skills. Both at a very high level.
Really amazingly entertaining. It's the only subscription I have on Youtube that i'll drop whatever i'm doing to watch. I used to work with a top class fabricator who now manages work on Bristols and it's artistry when it gets to that level, and the sarcasm is world-class Laughing
Post #612365 26th Mar 2017 9:38pm
MadTom
Czech Republic 1999 Defender 130 Td5 HCPU Baltic Blue
Thank you for the pictures. One question to the floor strengthening - I think it is perfect place for mud accumulating and rusting again. Try add some big holes. I had to weld the footwels and my solution to overcome this problem was 2,5mm thick sheet. No need for any strengthening. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #612441 27th Mar 2017 7:32am
Jim G
Nice to get some appreciation, Yes, agree about the rusting ! I am getting the bulkhead galvanised, and then my plan was to fill the ' strengtheners' with expanding foam to keep the water out before painting over. It was surprisingly strong ( in 1.5mm steel) before the strengtheners. 1984 300TDi hardtop Stornoway Grey
Post #612461 27th Mar 2017 9:44am
MadTom
Are you sure, that the foam will not absorb water? "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #612486 27th Mar 2017 11:17am
excossack
Maybe cap off the ends and leave a hole for the galv to get in, then before painting seal with seam sealer and fill with cavity wax then seal the holes with grommets? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #612513 27th Mar 2017 12:38pm
Jim G
Good idea, I think the foam is waterproof though , it floats, so probably doesnt absorb water, plus I will paint the ends and so seal it.... ask me in 5 years how it worked ! Confused 1984 300TDi hardtop Stornoway Grey
Post #612580 27th Mar 2017 4:43pm
