Home > Maintenance & Modifications > Bent Air vent flap |
Rallymental Member Since: 17 Aug 2015 Location: The Garden of England Posts: 468 |
It looks to me like the pin on the left is bent?
If it is, try this: http://www.lrparts.net/defender-stainless-...13654.html The definition of insanity is doing the same thing over and over again but expecting different results. Solihull, 1948 - "If we paint the chassis, it will last for years" Solihull, 2015 - "If we paint the chassis............................. |
20th Mar 2017 7:39pm |
Rosewellian Member Since: 19 Mar 2017 Location: Hampshire Posts: 7 |
Thanks I will order a set
20th Mar 2017 7:44pm |
It looks to me like the hinge on the right hand side that is welded to the flap has had the pin hole rolled over. I'd take the flap of and with some grips, unroll the pin holder until it's level with the other. Ray
20th Mar 2017 7:51pm |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4784 |
^ what Ray said 2002 90 Td5 Station Wagon
20th Mar 2017 8:49pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10513 |
+2 ^ ^ 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton. |
20th Mar 2017 10:06pm |
alwoodley72 Member Since: 14 Mar 2010 Location: salisbury, wilts Posts: 720 |
+3^^^^! Then you just need to replace the 'screen rubber.....
Cheers. Alex 98 300 tdi 90 project 94 Range Rover vogue 4.2 lse 79 911 sc 08 130 double cab utility |
21st Mar 2017 12:14am |
Thanks guys looks like I will be having a busy weekend! Vent Flap, windscreen Rubber & windscreen to bulkhead foam seal!
21st Mar 2017 10:22pm |
