Home > Td5 > A puzzling problem |
Does it sound like a ball bearing rattling around? And does the engine chirp when switched off? Ray
13th Mar 2017 12:27am |
roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039 |
Were the crankshaft bearings checked? Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
13th Mar 2017 8:54am |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4784 |
Also has injector lash been set correctly? 2002 90 Td5 Station Wagon
Chris86 Member Since: 15 Jul 2014 Location: South Yorks Posts: 755 |
Hello,
Thanks for taking the time to read and reply! In answer to your questions. it does sound like a marble rattling about in a box as it returns to idle and sometimes when its idling, other times its more like a diesel knock. I have not noticed it squeaking when turned off but I'll listen for it when I take it out later. -I'll try and record the noise if I can too. The crank bearings were inspected when the engine was stripped and the guy from the independent garage was quite happy with them-aside from the marking on the piston crowns he said that the condition of the engine parts was 'remarkable' for a 145k engine. The lash has been set three times, twice by garages and checked and set a third time by a friend. The injectors were coded too. Chris |
13th Mar 2017 9:51am |
Laurie Member Since: 22 Feb 2008 Location: Sussex, England Posts: 2897 |
I'm no expert but has the common rail part of the fuel system been pressure checked? Could be a pinhole leak bypassing an injector.
13th Mar 2017 12:02pm |
I have just managed to get a short video of it when its idling poorly and idling normally, I have no idea how to upload them though!
13th Mar 2017 8:12pm |
Paulv8 Member Since: 09 Jun 2013 Location: Milton Keynes Posts: 618 |
When the injectors were replaced, we're they correctly coded in the ecu? V8 90...WIP
13th Mar 2017 8:27pm |
It's also worth checking the gauze filter in the fpr... V8 90...WIP
13th Mar 2017 8:28pm |
Video of the bad idle when hot
Video of it idling normally when cold |
13th Mar 2017 8:29pm |
Mdm Member Since: 11 Sep 2013 Location: Sunny Lancashire Posts: 1526 |
hmm bit of a good one
did you use new head bolts etc on the rebuild? we have had a similar issue on a disco and the ecu was failing. replaced with a good one from another car,coded up injectors etc poor remaps often lead to these strange symptoms as well |
13th Mar 2017 8:59pm |
Yes, it was all done with new bits, it has done this both on standard mapping and its had a different map tried on it to see if it was a firmware or mapping issue.
Alive tried a different ECU on it, but they weren't able to get it to reproduce the fault with either ECU. Its a very frustrating fault, and it gets increasingly bad the hotter it gets- this was after a quick blast down a few motorway junctions and back. Chris |
13th Mar 2017 9:11pm |
Could be the crank sensor. It sounds like it's hunting a bit 2002 90 Td5 Station Wagon
13th Mar 2017 9:19pm |
@grafty, its had a new crank sensor
My wife was just tickling the throttle to demonstrate it at its worst during the video...... It wasn't fully hot through so was still settling (eventually) Chris |
13th Mar 2017 9:28pm |
Has the timing been checked? 2002 90 Td5 Station Wagon
13th Mar 2017 9:32pm |
