Home > Technical > Defender Security |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4791 |
If you use the search tool on the forum it will list alot of threads with different suggestions for security, varying from some very simple to some complex. Various layers is considered the best way.
Adrenaline Pedal lock or similiar Removable steering wheel Lock to go onto the steering wheel boss having removed the steering wheel Battery isolation switch Tracker systems There are lots and lots of different security measures you can take. Perhaps its best not to say how long you leave it parked in one place 2015 HT XS 90 2008 SVX 90 2000 XS TD5 90 |
4th Mar 2017 3:28pm |
PWC1c Member Since: 10 Oct 2015 Location: Hertfordshire Posts: 193 |
I am thinking steering wheel lock as its visual had a walk round and out of 10 plus Defender only one had one
4th Mar 2017 5:01pm |
apt100 Member Since: 05 Mar 2015 Location: Derbyshire Posts: 1547 |
In your situation I would definitely have some obvious physical security including a steering wheel lock and a pedal lock. A couple of minutes to fit them is irrelevant for you.
4th Mar 2017 5:09pm |
Any ideas on best steering wheel lock ?
4th Mar 2017 10:06pm |
I have the Disklok and that is probably the most popular for Defenders.
I also have an 'Ardcase pedal lock but its fair to say that there are a couple of other popular ones as well A search would bring up plenty of threads. |
4th Mar 2017 10:10pm |
