Page 985 of 1370 <123 ... 984985986 ... 136813691370>
Green Machine
Great to see you've had the V8 out today Steve (on Instagram). Looking and sounding spot on - testament to the amount of work you've put into it. Here's looking forward to the longer evenings and better weather! 2005 Td5 | 90 Station Wagon | Tonga Green
Post #603129 19th Feb 2017 8:33pm
ericvv
Post #603133 19th Feb 2017 8:53pm
JustFX
United Kingdom 2000 Defender 110 Td5 CSW Coniston Green
This weekend,
Saturday,
    Fitted New Mantec Snorkel.
    Replaced Blown reverse bulb with new LED one.
Sunday,
    New Alpine window seal (second still to do).
    New Window Door Seals (Rear Passenger doors)
    Rear Defender 110 Sticker removed and replaced.
Post #603134 19th Feb 2017 8:57pm
Nice^^^ it's the little details that make the differences to a tidy motor.
@GM thank you, though after a run around the block, I discovered a seal leaking Evil or Very Mad hence the oil catcher, Eric.
More spannering Big Cry
Post #603139 19th Feb 2017 9:37pm
AJC
The screws I used were left over from my kitchen install. I used countersunk ones but I did have a few wider flat headed ones I found better but only had 3 so put them on the 3 that are under the most stress. I drilled a 1.5mm hole as pilot and then screwed the screw in with cordless impact driver.
The screws need to be 10mm long
Post #603148 19th Feb 2017 10:18pm
TACK
Spot of camping while the weather was good.
Post #603155 19th Feb 2017 10:23pm
Rosco
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
Spent the day travelling the lanes of Wales with JST and Mountain Man.
Top weekend :thumbsup:
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone
2014 - Montalcino Red 110 XS SW
Post #603159 19th Feb 2017 10:30pm
L110CDL
Many thanks for the info AJC Bow down 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton.
Post #603162 19th Feb 2017 10:34pm
Sulisuli
Spent a cple of hrs with some ACF50 and a small paint brush very therapeutic Very Happy 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #603185 19th Feb 2017 11:21pm
^^^^ I've done that too, just today. Shocked
All be it without a paint brush. Diesel$ Live$ Matter. ⛽️🛢️👨‍🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
Post #603201 19th Feb 2017 11:55pm
Sulisuli
How did you apply it Steve? 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #603206 20th Feb 2017 12:27am
Well I only did under the cappings, bonnet hinges today, and the upper tub edge etc with the aerosol and straw.
Wipe excess off with a brand new terry towl / cloth.
However, for bolt heads etc which I'm guessing you have done a little brush is perfect.
There are plenty unde the engine bay, but some I prefer to do in the same method but wit black Dinitrol.
Don't with that, they really don't need doing again unless they are removed.
Obviously some visual fixings you don't always want black though.
I tend to wipe on and off ACF 50 on the door hinges too, as well as white lithium grease in the actual hinges.
I've been doing a really onslaught on mine the last few days. Thumbs Up Diesel$ Live$ Matter. ⛽️🛢️👨‍🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
Post #603210 20th Feb 2017 12:39am
Sulisuli
Its amazing the number of locations and places you can apply ACF50. You dont see anything for a cple of hours work but you know it was time very well spent and a little goes along way. I also used the aerosol version and if your careful proves to be very useful.
Gave my black chequerplate a wipe over with it and what a difference visually propably hasnt offered any protection to the chequer but got rid of the weathered effect.
Very impressive stuff 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #603214 20th Feb 2017 12:51am
Certainly is, I use White Diamond polish on CP. but that's because I have bare CP. Cant use it on coloured as it's slightly abrasive. Diesel$ Live$ Matter. ⛽️🛢️👨‍🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
Post #603217 20th Feb 2017 1:08am
With the promise of a couple of days good weather, I made a start on renewing the rear lights on my 90 this morning. It's quite involved as it's necessary to enlarge the holes in the bodywork and as those holes are in the steel corner cappings, they need to be painted.
So, with the old lights removed and the holes enlarged, they were given a quick blast of etch primer:
They'll get a touch of Arles blue tomorrow but I've also unearthed a more pressing problem. When I removed the cover on the back of the lights on the off side, it revealed this:
This is obviously where the towing electrics are connected but there are far too many Scotch locks for my liking. Also, the rear wiper doesn't work and I think I now know why! Darren
Post #603218 20th Feb 2017 1:16am
