Home > Puma (Tdci) > EGR Blanking Plate |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19578 |
It is a good idea yes. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
11th Feb 2017 12:04pm |
OldDD Member Since: 17 Jan 2016 Location: Ballaugh Posts: 53 |
Any idea where I can get one from??
11th Feb 2017 1:05pm |
Alive tuning. Or BAS.
I have the former but they are available elsewhere. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
11th Feb 2017 1:15pm |
Just had a chat with Gary the owner of Alive tuning.
He says it is always recommended to be fitted for certain. I think they have some on the site, they slip in between the two EGR mating faces then you retighten. Torque figures for the bolts are in my 'gallery' WSM. http://www.alivetuning.com/contact/ Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
11th Feb 2017 2:05pm |
Rickydodah Member Since: 14 Jul 2014 Location: East Sussex Posts: 1091 |
http://www.ebay.co.uk/itm/EGR-blanking-pla...xylpNTUkOV They also do versions for the 2.2 if that's what you need I started with nothing and still have most of it left! |
11th Feb 2017 2:18pm |
Thanks Guys
I'm slowly working through the list of improvements I want to make to this truck and the EGR block off is high on the list as I've had great results doing this with other cars. DPF /CAT delete next !! |
11th Feb 2017 8:08pm |
Scoobeenut Member Since: 04 Mar 2015 Location: West London Posts: 310 |
So if you fit the egr blanking plate what happens when you reload the standard factory tune map? Surely the standard map requires the egr to cycle and if not does this throw out engine fault codes?
11th Feb 2017 8:17pm |
It probably does but I have absolutely no intentions of ever going back to the standard map. It's pants!!!
11th Feb 2017 8:29pm |
Froglaise Member Since: 24 Sep 2016 Location: left forum Posts: 212 |
You get a light on the dash and a quieter engine with a bit better performance at times (possibly imaginary). I have an Alive map and egr blanking and have gone back to the standard map but the plate is staying in. |
11th Feb 2017 8:31pm |
I always reload the standard map when I put it in for service or maintenance as I don't want the garage to overwrite anything onto the tuned map.
11th Feb 2017 8:45pm |
^^^^ Same here. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
11th Feb 2017 8:50pm |
Mine is a Twisted so they know it's tuned and never plug in / rewrite.
11th Feb 2017 8:57pm |
I presume this is not the td5 in your sig Ray
11th Feb 2017 9:09pm |
Haha!!
No, I'll have to change that - Sold Darth last year and picked up a very nice Twisted 90 TDCI to replace it. |
11th Feb 2017 9:15pm |
