Home > Maintenance & Modifications > bowler transfer lever
Likeomg
didn't get any instructions.... how long do i cut it?
anyone know of online instructions... cars half apart Sad
Post #599936 7th Feb 2017 9:50pm
Romadog
From TMD Tuning's website .....
However the Diff lock lever is not so simple, as the original lever does need to be modified.
You have to remove the outer gear lever rubber knob, this will require cutting, once removed you need to cut the metal lever at the required length to enable fitment of the new lever, the metal lever will require cutting with a angle grinder.
Not very detailed is it Crying or Very sad
Post #599940 7th Feb 2017 9:53pm
Likeomg
nope Sad
Post #599947 7th Feb 2017 10:11pm
shaggydog
Not brilliant considering how much they are Shocked Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #600089 8th Feb 2017 1:56pm
bankz5152
I never thought they would be at all comfortable either!
Post #600096 8th Feb 2017 2:33pm
TJ101
Very happy with mine,, nice positive feel to the stick now
But sorry, i bought mine already modified, and were a direct replacement Smile
 California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #600237 8th Feb 2017 11:16pm
Likeomg
there fitted...
another busy day... the new sub is a little bit ridiculous, hopefully all finished tomorrow, hannibal rack and lazer on saturday morning then off to twisted for all my new leather bits next week
Post #600242 8th Feb 2017 11:24pm
Romadog
And the answer is.... Question Question
Post #600310 9th Feb 2017 11:13am
JOW240725
Photos, photos, photos Thumbs Up Bow down James
Instagram @suffolk_rovers
Post #600311 9th Feb 2017 11:13am
Likeomg
didn't take one of how i cut it but fairly easy to explain with the following...
i sliced the existing transfer stick off, theres a nylon white bit left on the steel bar, you don't need a angle grinder like stated just a good quality blade...
Been busy as installed a slick shift at the same time and it rattles like you wouldn't believe, shifts beautifully but that rattle...
Will re install my SVX gearstick and see if its the weights... otherwise hopefully this ghetto tape fix for the slick shift works otherwise I'm not a happy bunny having just stuck down a brand new premium carpet set ill have to tear up Evil or Very Mad
This is the required length to cut it, i eye balled it and got it mm perfect...
Post #600567 10th Feb 2017 6:18am
racy31
United Kingdom 2011 Defender 110 Puma 2.4 USW Java Black
TJ, your lever looks to be fitted 180 degrees out to the ones in the stock pics
Post #603591 21st Feb 2017 2:46pm
racy31
'Been busy as installed a slick shift at the same time and it rattles like you wouldn't believe, shifts beautifully but that rattle...
Will re install my SVX gearstick and see if its the weights... otherwise hopefully this ghetto tape fix for the slick shift works otherwise I'm not a happy bunny'
Did you get the rattle on the Bowler stick as well? Ive got the rattle on the standard lever (and it isn't the weights). Was hoping a different lever would solve it.
Post #603595 21st Feb 2017 2:54pm
TJ101
Correct, Well spotted
Works for me, when fitted the other way round, Cubby lid opens, Levers fall to hand better from cubby lid California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #603597 21st Feb 2017 2:57pm
Likeomg
Rattle on all 3 gear sticks, bowler being worse...
I've taped it and done the weights now which is better but still get a rattle
I was also at probably the most 'premium' defender modifiers yesterday who also said they've had a fair few issues with them...
Post #603601 21st Feb 2017 3:09pm
TJ101
??? Shocked
No rattles on mine ?? but still under 6,000 miles California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #603604 21st Feb 2017 3:30pm
