Home > In Car Electronics > Td5 Wiper Fault
Harry.O
United Kingdom 1989 Defender 90 300 Tdi ST Nato Green
Td5 Wiper Fault
In the last few days the wipers on my 2005 Defender have developed an intermittent fault, hoping someone could confirm my suspicions?
If i push the lever down for intermittent wipers they work but sometimes randomly stop. Likewise putting it onto the slow speed continuous wiping has the same issue. However if i put them onto quick wipe then back to slow or intermittent they seem to work fine most of the time.
They always return to the bottom of the screen which I think rules out the park switch and given that they work sometimes I suspect the relay/earth is ok, does this point to the stalk itself having an issue?
Thought it best to check before spending money on parts unnecessarily Very Happy
Thanks, Harry
Post #591793 10th Jan 2017 11:56am
dorsetsmith
Remove the intermittent wiper relay its under dash check for broken solder joints in the PCB
Post #591797 10th Jan 2017 12:28pm
Harry.O
Thanks Dorsetsmith, I'll pop it out tomorrow and have a ganders. Sorry for the stupid question but presume the pcb is the board inside the relay?
Post #591882 10th Jan 2017 7:12pm
dorsetsmith
If you remove plastic case from the relay you see small PCB and the solder joints
Post #591899 10th Jan 2017 8:06pm
Harry.O
Problem solved, thanks Dorsetsmith Very Happy I couldn't see anything that looked out of the norm inside the PCB but picked up a spare from a local breakers and all seemed to be working, thanks once again Thumbs Up
Post #592407 12th Jan 2017 11:53am
dorsetsmith
No problem had same thing happen, fitted replacement relay and then find dry solder joints in old one, now have a spare one Thumbs Up
Post #592411 12th Jan 2017 12:02pm
Harry.O
I spoke too soon, the wipers have thrown a wobbly again. Mad
Now there is no intermittent wipe and no continuous at the slower speed either, the relay does click when the stalk is moved but not always.
Fast wipe works fine but when moved back to slow wipe the wipers stop wherever they are at the time. I had a spare stalk so tried that and it made no difference.
Could it be the relay once again or the wiper park switch perhaps?
Post #599270 5th Feb 2017 4:25pm
mk1collector
I'd go for park switch, they are cheap and are usually the cause wiper problems Ray
My build thread
Post #599288 5th Feb 2017 5:54pm
Harry.O
Thanks Mk1collector, I swapped the park switch for a new one just now but that doesn't seem to have made any difference either sadly.
Having tested the 3 terminals on the output side of the park switch just now, with the wipers switched to slow speed i'm getting power on the red terminal and on high speed the yellow has power which leaves the blue as earth I presume?
This makes me think that with power up to it being ok, the motor itself has a fault. Can anyone confirm my suspicions before I shell out for a new one?
Thanks, Harry
Post #599319 5th Feb 2017 7:03pm
grafty99
Have you tested the switch on the column? 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #599330 5th Feb 2017 7:41pm
Harry.O
I've not tested it but swapped it for a new one and the the wipers are still the same.
Given that power is being delivered to the motor by the fast and slow supplies (dependent on stalk setting) I presumed it was ok?
Thanks, Harry
Post #599337 5th Feb 2017 7:52pm
mk1collector
If you disconnect the motor from the wiper wheel boxes then try to rotate the wipers do they feel seized? Ray
My build thread
Post #599338 5th Feb 2017 7:54pm
dorsetsmith
Post #599339 5th Feb 2017 7:55pm
Harry.O
Thanks for your help guys Thumbs Up
I pulled the wiper motor out with the drive cable, the spindles turn nicely and there is no damage to the cable itself. Having detached the cable from the motor and popping it back through the spindles, they turn fine as well so nothing untowards in there.
I then circuit tested the 5 wires that go into the park switch as per Dorsetsmith's diagram and got the below results:
Reciving Power N/Y
Plug No Colour----------------Slow Speed--------Fast Speed---------Intermittent
C0000-1 Black
C0000-2 Brown / Green --------N--------------------N---------------------N
C0000-3 Blue / Green --------N--------------------Y----------------------N
C0000-4 White / Green ---------Y--------------------Y----------------------Y
C0000-5 Red / Green ---------Y--------------------N----------------------Y
It's interesting the C0000-2 never seems to get power?
Had a look inside the wiper motor and the main drive cog looks messy/worn but it spins smoothly in fast speed. At slow speed the motor clunks and knocks in your hand. Slow speed only seems to engage once it's been moved to fast then back to slow and it randomly stops irrespective of where the park switch tells it to.
It seems like there is a faulty connection or bush inside the motor given how much it bangs. Does this sound like it's time for a new motor?
Harry
Post #599570 6th Feb 2017 2:32pm
grafty99
There maybe someone local to you who can rebuild it. There is a company near me that repairs motors and they're quite reasonably priced Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #599613 6th Feb 2017 5:53pm
