Home > My Defender > Defender 90 LS/6L80 conversion. step by step! |
psimpson7 Member Since: 20 Nov 2013 Location: Gold Coast, Qld. Posts: 221 |
Done a bit more on this.
All the emissions hoses are now fitted. I started going through and fitting hose clamps to everything: Click image to enlarge Click image to enlarge Gauges have also arrived: Click image to enlarge Click image to enlarge Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated 2001 90 HT 6.0LS/6spdAuto. 2003 90 td5 soft top. 2014 90 XS SW 2.2. |
3rd Feb 2017 12:21am |
looks pretty good I think!
3rd Feb 2017 7:13am |
Andy80 Member Since: 31 May 2013 Location: Essex Posts: 485 |
Very OEM looking Where are you mounting the volt gauge? Andy Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Working towards Carry on camping! |
3rd Feb 2017 8:35am |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7875 |
Looks great! James
3rd Feb 2017 10:05am |
100inch Member Since: 15 May 2012 Location: Brunswick Posts: 407 |
Dash looks great. Do you have any way to see the O2 Sensor(s) readings? It will be very helpful at the start till everything runs perfect, same with fuel pressure IMO.m
3rd Feb 2017 12:38pm |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10363 |
Love the gauges!!!
3rd Feb 2017 12:43pm |
Thanks guys,
Fuel pressure regulator has a gauge so that aspect is done. I dont have anything to read the 02 sensors yet. Got a bit more done Click image to enlarge Click image to enlarge GPS Sensor for the speedo: Click image to enlarge putting the dash back together... Click image to enlarge Click image to enlarge Instruments connected up and go through the test sequence when ignition is on. GPS got a location within a minute or so. Dimmer for the lighting also works nicely. I managed to strip out the unnecessary pins from the multi pin plugs for the instrument panel and reuse the required ones for the feeds, earths and lighting. Click image to enlarge One step backwards tho..... The indicators have stopped working. Hazards are fine however. I assume I have removed something I shouldn't have in the loom. I am now doubting myself as to whether I actually tested them when I put the loom back in or if I just tested the hazards as it was quicker... Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated 2001 90 HT 6.0LS/6spdAuto. 2003 90 td5 soft top. 2014 90 XS SW 2.2. |
4th Feb 2017 9:40am |
How long to go to the first start?
4th Feb 2017 10:06am |
Its very close now but I am a bit tied up for the next few weeks so I may not get much more done till the start of March 2001 90 HT 6.0LS/6spdAuto.
5th Feb 2017 12:11am |
JJ Member Since: 18 May 2009 Location: Winchester Posts: 932 |
Looking forward to the video when the engine fires. HR064 Hampshire and Berkshire 4x4 Response
5th Feb 2017 12:14am |
Fixed the indicators. Fuse had gone!
Tidied up the wiring in the back of the instrument panel a bit too. Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated 2001 90 HT 6.0LS/6spdAuto. 2003 90 td5 soft top. 2014 90 XS SW 2.2. |
5th Feb 2017 11:40pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10530 |
Great it was a simple fix 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton. |
5th Feb 2017 11:42pm |
Another bit done
Oil pressure switch adaptor for the engine which I have been waiting on a while. Interestingly this was made on a friends CNC lathe as he had his CNC VMC in bits. Click image to enlarge I also managed to pick up a Puma 90 headlining out of a 2012 puma for $50 as the owner fitted a new one due to a couple of minor marks. It's far better than mine was. I have already fitted the front half, but the rear will take some adjustments due to the roll cage Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated 2001 90 HT 6.0LS/6spdAuto. 2003 90 td5 soft top. 2014 90 XS SW 2.2. |
13th Feb 2017 9:36am |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2078 |
Those gauges are erotic. I love them.
13th Feb 2017 1:22pm |
