Home > Td5 > Does any one change their own filters and oil?
Page 1 of 3 123>
BCdefender
Canada 1999 Defender 110 Td5 CSW Orkney Grey
After spending an absolute fortune on my TD5 oil changes and filters I've decided to take the plunge and start doing it my self.
Not sure why I wasn't already as I love working on the rest of the truck.
Does anyone have a list of what you actually need in terms of tools to get the job done?
I'm going start bringing in the filters and washer from Land Rover direct ie: LPX100590G, ERR6299LR, CDU1001L
Thanks for the Newbie feedback 1999 Defender 110
2003 P38
2007 RR SC
"And that's why it needs to be celebrated, because when the Defender goes we'll have lost this pointer to where we came from, and we're really going to miss it."
My build thread: http://www.defender2.net/forum/topic47750.html
Post #597160 29th Jan 2017 1:50am
miker
I've always done my own, saved a fortune over the years! Nothing special on tools, you may need a strap/oil filter wrench for the cartridge filter. I've always gotten lucky and been able to heave the ones I've dealt with by hand. The rotor filter cap is just two bolts, but these can be easy to cross thread.
Replacement sump plug & washer is a safe bet for reducing the chance of one source of leaks (there are many!)
I think you should always change the rotor filter and cartridge filter each time you change the oil, others are more liberal. Mann and Mahle both make very good filters, probably cheaper than "genuine" but easily the same quality (probably the same part!!)
Make sure you've got a generously proportioned drain pan, it takes 7+ litres!!
Post #597163 29th Jan 2017 2:40am
agentmulder
Kuwait
Unsure about Td5 exactly, but just saying good on ya for DIY.
Second time round will be much faster than first Thumbs Up Solved the bowel problem, working on the consonants...
Post #597165 29th Jan 2017 5:55am
rallysteve
Get the oil filter spanner for the td5 filter as it makes it so much easier to remove and refit. But be aware it only works with genuine and a few aftermarket filters.
84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale
Post #597174 29th Jan 2017 8:48am
Vogler
Belgium 2015 Defender 110 Td5 HT Chawton White
Most suppliers sell filter sets with everything you need and which are much cheaper than the cost of the separate items.
I always have a spare set so I can continue when something goes wrong. During the last change the plastic thingie of the fuel filter broke, so I was very happy to have a spare
I meticulously followed the LR workshop manual and applied threadlock to the R380 drain plug. But go easy there because its very very stuck now.
Two basic things you probably know:
- always undo the filler plug first so you are sure that you can fill after having drained
- put a magnet in the oil drain pan to check for swarf or signs of damage and wear.
- life is much easier when you use a kind of oil pump to fill the gearbox. It's very cramped there.
Joris
Post #597177 29th Jan 2017 8:56am
Vogler
You'll probably need some extra tools, especially a Torx T55 for the transfer box filler plug. Furthermore a 1/2" drive ratchet for most plugs, and a large hex spanner (I think 32mm) or a 3/8 drive ratchet for the gearbox - the two latter depending on the year of production (pre or post 2005).
J
Edit: Thx for the correction below ibexman.
Post #597181 29th Jan 2017 9:17am
ibexman
Torx t55 is main gearbox Whistle
Post #597185 29th Jan 2017 9:55am
barbel jim
I only use genuine filters. There are others who will disagree, but for a few extra £ I believe its well worth it
Post #597187 29th Jan 2017 10:04am
roel
quality brand filters may even be better then genuine. Twisted Evil
Download the servicesheet and follow that.
The td5 main filter is nat very easy placed but still better the on the D3 V8. I can't replace them without making a mess. I just break it loose with my chaintype spanner and then get a plastic bag and push it as fa as possible over it and then unsrew it by hand. That saves me a lot off oil on the ground.
I don't know if you downloaded the Rave 02 disc allready it will help you a lot if you never done this before. The first time it will take you some time but after the second time you ask yourself: Why did I pay for this in the past? Mr. Green
Do it, I find it very rewarding. Roel
2003 90 Td5 (2009-now)
Post #597217 29th Jan 2017 11:30am
williamthedog
Yes ,do it yourself and you know it's done correctly Thumbs Up
Post #597226 29th Jan 2017 11:54am
g-mack
Post #597228 29th Jan 2017 12:03pm
Tommo
United Kingdom 2006 Defender 90 Td5 Black LE Java Black
Use genuine filters and fluids as you`re already saving a fortune by doing it yourself.
I usually buy a TD5 service kit from dealers and get it for about £65.
Use quality fluids, buy coolant, gearbox oils etc from dealer and negotiate a price.
Ironically some would spend £££ on modifications and complain about the cost of genuine filters etc....don't understand it
myself Shocked
Post #597312 29th Jan 2017 4:16pm
roel
1. As a genuine filter can easlily be 30% more expensive by the dealer then the same genuine filter by another supplier.
2. Land Rover doesn't make the filters and oils themselves. So you can get the same filter in another box and the same oil in another can.
3. Are genuine the best products???
So look somewhere else and try to find the best and compare the prices. Whistle
And yes I have some additional items on my 90, but most made by me or secondhand. Twisted Evil
Yes even the tyres are secondhand. Roel
Post #597321 29th Jan 2017 4:49pm
gilarion
Always do my own and have fitted a Difflock drain plug, makes oil draining so simple and mess free, would recommend this mod to anyone once fitted (ten minute job) you do not need sockets or spanners ever again and the removal tube/pipe fits into a drain can, perfect.
More info here http://www.defender2.net/forum/topic29173....drain+plug For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #597323 29th Jan 2017 4:52pm
Daisy90
United Kingdom 2001 Defender 90 Td5 SW Alveston Red
Another vote for difflock drain plug kit job by,
Also, put a small bag around / underneath the main oil filter after you have loosened it, this will catch the oil from the filter when your removing it from the engine area
With both the above - it's quite a clean job these days Thumbs Up
Post #597344 29th Jan 2017 5:39pm
Page 1 of 3 123>
