Home > Technical > Diagnostic reader for 300 TDi 90
Roosterrs
I have connected a Snap on Ethos fault reader to my 1997 300TDi Defender, but it wont connect. This is through the port between the centre and passenger seat. Does anyone know if the Snapon kit works? If not what readers do work?
Post #596022 24th Jan 2017 9:31pm
Disco_Mikey
Scotland 2009 Defender 110 Puma 2.4 DCPU Keswick Green
I'd be highly surprised if ANY diagnostic kit worked on a 300TDi Laughing
In all seriousness, there will be something to connect to the alarm module for coding key fobs etc, but that's about it
Post #596027 24th Jan 2017 9:42pm
Roosterrs
Ok no worries, just trying to see if the alarm module was causing an issue on my vehicle. Scrolling through the menus it says 1997 10th letter of VIN =V but only showers discovery, freelander and range rover. Scrolling through a couple of menus does show defender and states where the connection is, but won't read. Thanks for your help.
Post #596034 24th Jan 2017 9:49pm
dorsetsmith
The only two thing 1997 300 TDI EGR control unit and 10AS alarm unit
Post #596037 24th Jan 2017 9:56pm
Procta
where is the Diagnostic port on the 300? Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #597051 28th Jan 2017 7:48pm
dorsetsmith
Post #597103 28th Jan 2017 10:06pm
thompjas
The port is at the front of the middle seat / cubby box area and close to the passenger seat if that makes sense !
Post #598057 31st Jan 2017 5:17pm
Tia4
United Kingdom 1998 Defender 90 300 Tdi SW Cairns Blue
I have these ports under my middle seat always wondered what they were for. I see they are diagnostic ports but what would they check for? It's a 300 tdi
Post #598622 2nd Feb 2017 5:52pm
dorsetsmith
EGR control unit programming and 10AS alarm unit programming it more a programming port as no ECU is fitted to 300 tdi late model
Post #598639 2nd Feb 2017 6:38pm
