Home > Td5 > Model year for 15P engines? |
15p engine 2002 onwards i.e. face lift centre dash
23rd Jan 2017 11:33am |
Cactus79 Member Since: 09 Jan 2017 Location: Cheshire Posts: 51 |
They will also have an EGR cooler on the front of the engine
23rd Jan 2017 1:18pm |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1758 |
Engine number will start 15P as well. 3 port fuel pressure regulator.
23rd Jan 2017 1:21pm |
23rd Jan 2017 1:24pm |
@dorsetsmith. Oops. Brain-finger interface problem!
23rd Jan 2017 1:39pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6482 |
2002 model year so those from late 2001 onwards. As above, with the console around the radio with all the switches, and the one-piece rear door. 1988 90 Td5 NAS soft top
2015 D90 XS SW |
23rd Jan 2017 1:58pm |
VVS210 Member Since: 12 Nov 2016 Location: Hampshire Posts: 953 |
Thanks all - the facelift dash is a good visual pointer
Interesting point about EGR cooler as I removed the EGR valve from my D2 which had a 15P engine and don't remember there being any form of cooling associated with it, e.g. a water jacket and plumbing - does anyone have any photos of the EGR valve with cooler please? I still have the one I took off my D2 in the barn somewhere so will dig it out and see if my memory is failing me... |
23rd Jan 2017 2:01pm |
Click image to enlarge |
23rd Jan 2017 2:09pm |
dan_the_v8man Member Since: 25 Jan 2017 Location: Sheffield Posts: 3 |
If in doubt, check the V5, the engine number should start with 15p or 16p (not 100% if the 16p was just fitted to the D2 but eitherway, don't worry if it says 16p)
25th Jan 2017 9:54am |
So... My old D2 was '53 plate fitted with a 15P engine (confirmed by checking the engine number on an old V5 I have for it from when it had a cherished plate on it) but the EGR valve did not have a water jacket as the photo below shows?
How come the Defenders with 15P engines have it and is it to cool exhaust gas or keep it warm to stop the black sludge blocking the pipe up?? Click image to enlarge |
25th Jan 2017 4:38pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16879 |
The clue is in the name, "EGR cooler", not "EGR warmer"!
I certainly thought that all 15P engines had the cooler, since it was fitted as part of the emissions compliance upgrade required at the time. My 2002 pre-facelift Disco2 has a 15P engine and has the cooler. Is it possible that your vehicle was intended for export, or has had the cooler replaced with an earlier pipe? Most poeple don't bother to remove the cooler when removing the EGR and just leave it in situ and plumbed into the cooling system still. I removed mine and rerouted the associated pipes, mainly just to tidy up the engine bay and remove potential faults. |
25th Jan 2017 5:03pm |
Bought my D2 from a dealer with one owner & full LR service history & 51k on the clock. No redundant plumbing floating about when I removed the EGR valve that I can recall, suggests it was 'as built' when I removed it?
25th Jan 2017 5:19pm |
For no other reason than because I wanted to know the answer I did a bit of trawling on the internet and it seems that for some reason whilst early facelift D2s had an EGR cooler the very late models reverted back to the original version with no cooler whilst the Defender kept it - no idea why
26th Jan 2017 12:38pm |
That is interesting, I did not know that! I wonder why.
Perhaps LR found that the EGR cooler actually did nothing useful. |
26th Jan 2017 1:05pm |
