Home > Puma (Tdci) > Rear Door / Boot / Tail / Central Locking
ngins
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Corris Grey
Sorry if this is elsewhere but I have searched and searched! The rear door on my 2013 Puma XS 110 doesn't ever seem to unlock with the central locking. I have driven a few post-2012 90 and 110s and after first unlocking with the key the central locking then always operated the boot. I don't think there is anything configurable in the alarm to stop the rear door only for unlocking so I assume WD40 will sort it (which I will try) but just wondered if anyone knew any different. The actuator works fine to lock the door but then I seem to need to unlock every time with the key, which has not been the case in other Defenders I have driven..... Just wanted to be sure it is likely to be an actuator/mechanical issue rather than some alarm configuration I don't know about.
Post #594990 21st Jan 2017 5:07pm
grafty99
I would have said it's likely to be the actuator, take the rear door card off and have a look to see/hear if it is trying to unlock then go from there Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #594993 21st Jan 2017 5:14pm
mk1collector
Or maybe broken wires in the rubber boot from the pillar to the door. Ray
My build thread
Post #595060 21st Jan 2017 8:44pm
ngins
Thanks for the suggestions. Will take a look.........
Post #595142 21st Jan 2017 11:32pm
