Home > Technical > Alternate puma fuel filter? |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 3997 |
Personally, as a layman unless there is some reason why the standard filtration in inadequate I wouldn't change. I'd be worried about the the finer filter putting more stress on the fuel pump or restricting flow or something. That's unless you can find a technical expert to say it's fine to swap. 2007 110 TDCi Station Wagon XS
19th Jan 2017 6:13pm |
Bushpig Member Since: 07 Nov 2013 Location: Risca, Wales Posts: 236 |
I fitted a second filter...
Have a look at the thread http://www.defender2.net/forum/topic48466.html Human beings, who are almost unique in having the ability to learn from the experience of others, are also remarkable for their apparent disinclination to do so. Douglas Adams 2012 2.2 Puma |
20th Jan 2017 5:56am |
MR_JAMES Member Since: 10 Oct 2013 Location: ESSEX Posts: 242 |
I did some homework on this a few months ago. From a few online sources I learned that all transit 2.4 /2.2 tdci filters are 2 microns (as it is common rail and uses very high fuel pressure) Whereas the di uses a 5 micron filter.
I fitted a genuine ford filter for the tdci - its a little bit longer than the rover branded version but in my view better. 1953 80" 1987 mini city e 2011 90" |
20th Jan 2017 10:35pm |
^^ Interested to know why it is better? Solved the bowel problem, working on the consonants...
20th Jan 2017 11:26pm |
