![]() | Home > Expedition & Overland > Unbraked Land Rover trailer axles? |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 3608 ![]() ![]() ![]() |
Best I could google at the mo.
custom90steve Member Since: 21 Jan 2010 Location: South West Posts: 15624 ![]() ![]() ![]() |
That's a very interesting link ^^^^
pj2106 Member Since: 20 Dec 2012 Location: Huntingdon AKA The Shire Posts: 895 ![]() ![]() ![]() |
Buy an old horse/livestock trailer and use the axles probably be cheaper 2008 110 2.4 XS Utility (Hagrid)
muddybaldboy Member Since: 09 Apr 2012 Location: Ruthin Posts: 386 ![]() ![]() ![]() |
pm sent |
Bushpig Member Since: 07 Nov 2013 Location: Botswana Posts: 170 ![]() ![]() |
Not sure if a LR axle will fit your trailer...
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 1327 ![]() ![]() |
Bear in mind that any weight you add will diminish your available payload, so replacing a relatively light beam and Indespension unit type axle system with a far heavier LR axle or LR hubs could be a problem depending on how much of the payload on your trailer you regularly use. |
Retroanaconda, indeed you are correct about reducing the payload of the trailer.
Manxie Member Since: 29 Oct 2016 Location: Isle Of Man Posts: 26 ![]() ![]() ![]() |
Thanks very much for the link, that's great. Also it's looking like MBB might be able to help out with a pair 👍 |
Site Copyright © 2006-2018 Futuranet Ltd & Martin Lewis
