Home > Td5 > Defender 2003 TD5 Black smoke and rattle
andylee
Hi Guys I'm looking for some advice and maybe a check list before I talk to the garage about the following problem.
Vehicle starts first time from cold and revs normally with slight smoke, nothing unusual or worrying.
When pulling away in first and into second gear there is a slight rattle from the engine at what Im guessing is about 2000rpm and thick black smoke comes out then clears as the revs increase. There is no loss in power. Once the engine is up to working temperature the problem disappears and everything runs fine with no smoke and no power loss but Im concerned that a problem is looming and want to get it sorted.
I have checked the ECU loom for oil at the ECU end and its fine.
How can I check the MAF and EGR ? Ive heard these can stick open/closed and cause problems at low revs under load!
is there anything else I can check to help diagnose this ?
your advice is appreciated,
many thanks
Andy
Post #589856 3rd Jan 2017 8:34pm
pj2106
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
Best bet would be give Gary at alive or Pete at bell autos a call see what they say 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold
1998 300TDi D1 (Billy) Sold
Post #589862 3rd Jan 2017 8:45pm
lightning
Disconnect the MAF unit and see if it's any better.
Post #590230 4th Jan 2017 10:08pm
MadTom
Czech Republic 1999 Defender 130 Td5 HCPU Baltic Blue
Check also the air hoses between turbo and intercooler and intercooler and engine. They can fail from inside forming a "flap". "Drobek" = The Small One - Discovery 2, "BlufĂ­nek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #590359 5th Jan 2017 1:39pm
bob neville
Also check the turbo actuator arm is moving.
Sorry to say it sounds a bit like mine just before the turbo went bang.
2013 Defender 90 CSW - sold
Post #590442 5th Jan 2017 6:54pm
